Page 3 of 4 1 2 3 4
Re: Parking brake won't hold, what am I missing? [Re: TJP] #3080372
09/24/22 09:36 PM
09/24/22 09:36 PM
Guitar Jones Offline OP
That's the big brake pedal. laugh2
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Parking brake won't hold, what am I missing? [Re: Sniper] #3080380
09/24/22 09:49 PM
09/24/22 09:49 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I wonder why when you grab that handle on the floor console or between bucket seats and pull on it real hard and the car's rear wheels lock for a moment, then the car spins 180 degrees they call it an "E-brake turn".....................just saying wink Maybe before the 1966 Federal Motor Vehicle Safety Standards (FMVSS) and the dual chamber master cylinders it was sometimes termed and actually used as an "emergency" brake/braking method but not today. A lot of this is now the Kleenex vs tissue, Xerox vs photo copy, "dialing" a phone number vs pushing buttons to call someone, and a hundred other "genericizations". At one time it was on some vehicles an "emergency" and parking brake but there ain't no way (yep ain't and a double negative grin tonguue ) that cable device is going to stop a vehicle, maybe it will slow it down like a fly on an elephants butt would create wind resistance laugh2 wink
From Wiki and "Parking Brake" : The parking brake in most vehicles is still completely mechanical. Traditionally engaged by pulling a lever, the cables manually engage part of the car's braking system, usually the rear disk or drum brakes.[12] The mechanical nature allows the driver to apply the brake even if the main hydraulic brake system fails.[7] Good luck with that wink
Re: Parking brake won't hold, what am I missing? [Re: TJP] #3080439
09/25/22 08:20 AM
09/25/22 08:20 AM
IMGTX Online content
IMGTX  Online Content
I am not used to the term service brake either.
On a couple of the bigger trucks I have driven they had a brake button on the dash. I didn't drive a lot of bigger trucks so I am not sure what it was called but you set it when you parked.
While in high school I had a Mustang II. The pull handle between the seats identified as a drift enabling lever.
I also had a 66 Charger pop a wheel cylinder. While going down a slight incline the brake pedal decided to identify as an accelerator.
Re: Parking brake won't hold, what am I missing? [Re: larrymopar360] #3080466
09/25/22 10:38 AM
09/25/22 10:38 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Originally Posted by larrymopar360
So back in the days of a single master cylinder, if it leaked out on your car would you yank on that cable operated "parking brake" or say to yourself nope, that's the parking brake stirthepot
YES, happened on two separate vehicles, my 64 4 speed plymouth and a 62 dodge auto. Now both times I was going 30 mph and getting ready to make turn, both times the rear rubber line to axel broke. A little understanding here, with drums in the back the cable acts the same as pushing the brake pedal (it has a LONG arm for better leverage force). When disc brakes are used there’s a tiny set of shoes inside the disc, real good for holding a vehicle at rest, not to good for emergency situations. The mechanic next door just replaced the complete assembly on 2001 Dodge mini van where the guys daughter left the emergency brake on. Only one side was engaged, she said she had to keep the gas pedal flooded to get back home, NO CLUE what the problem was. Fried the drum, burnt the linings off the shoes, smoked the wheel cylinder and warped the backing plate. She did add it got easier to get up some speed after awhile (linings gone).
BUT even in the new cars your ‘parking brake’ WILL STOP YOUR CAR IN AN EMERGENCY.
One more thing, not sure of back in the day if the car companies were lawyered up like today for lawsuits but saying it’s a parking brake let’s them off the hook if said device were used in an ‘emergency’ situation that didn’t end well. It’s all about correct ‘wording’
Re: Parking brake won't hold, what am I missing? [Re: Guitar Jones] #3080511
09/25/22 01:00 PM
09/25/22 01:00 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I have never heard of a brake pedal being called a "service brake" shruggy
If you refer to my first two posts, using the "SERVICE BRAKE" in conjunction with the "PARKING/EMERGENCY brake" was one of the suggestions I made. Might not have worked so well with the detached cable shruggy But it is something I has done for years especially with a stick trans on a steep grade wink
Glad you got it sorted and thanks for the update up
Re: Parking brake won't hold, what am I missing? [Re: TJP] #3080527
09/25/22 02:07 PM
09/25/22 02:07 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Way to go Guitar, start a huge fight on Moparts with riots likely to follow, and all over the parkmergency brake.
Facts are stubborn things.
Re: Parking brake won't hold, what am I missing? [Re: larrymopar360] #3080532
09/25/22 02:19 PM
09/25/22 02:19 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
That's Emergencypark break (yeah "break" is deliberate tonguue ) catfight argue musik laugh2 laugh2 grin
Re: Parking brake won't hold, what am I missing? [Re: A12] #3080548
09/25/22 03:02 PM
09/25/22 03:02 PM
Tennessee
CUDASCOTT Offline
CUDASCOTT  Offline
Tennessee
Well I’ve heard some good arguments before but this one isn’t one of them. The hand brake/E brake park brake what ever you decide to call it of all of them the hand brake was the fist braking system used on a vehicle. When the hydraulic brakes came along the hand brake was left to use as an emergency brake if the hydraulic brakes failed.
https://www.wagnerbrake.com/technic...ance/all-about-your-emergency-brake.html
Re: Parking brake won't hold, what am I missing? [Re: CUDASCOTT] #3080552
09/25/22 03:25 PM
09/25/22 03:25 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I wonder how many will read this?
Re: Parking brake won't hold, what am I missing? [Re: A12] #3080567
09/25/22 04:17 PM
09/25/22 04:17 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
laugh laugh laugh
Re: Parking brake won't hold, what am I missing? [Re: cudaman1969] #3080568
09/25/22 04:18 PM
09/25/22 04:18 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I don't plan on it but "fist braking" sounds painful
Re: Parking brake won't hold, what am I missing? [Re: TJP] #3080628
09/25/22 08:29 PM
09/25/22 08:29 PM
Service brakes is the term the factory uses to describe the main braking system, in other words, the big brake pedal. Just funnin' with ya.
The cable that came off was for the self adjuster mechanism, had no effect on the operation of either (service or parking) brake operation.
Re: Parking brake won't hold, what am I missing? [Re: larrymopar360] #3080631
09/25/22 08:36 PM
09/25/22 08:36 PM
I know right?
Re: Parking brake won't hold, what am I missing? [Re: Guitar Jones] #3080900
09/26/22 05:38 PM
09/26/22 05:38 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I know right?
laugh2
Re: Parking brake won't hold, what am I missing? [Re: SNK-EYZ] #3080942
09/26/22 07:25 PM
09/26/22 07:25 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
Originally Posted by SNK-EYZ
Originally Posted by Golden-Arm
Originally Posted by Sniper
Originally Posted by stumpy
They were emergency brakes long before they started being called parking brakes. It is common knowlege that in a case of regular brake failure the hand brakes ( emergency brake) could be used. You really need to realize the FSM doesn't tell you everything. Look it up online a see a hundred of explantions of the reason for emergency brakes by some very reliable sources like OSHA etc.not BS websites.. Yes using it as a parking brake is recommended.
Prove it. One link from an authoritative source. They were never emergency brakes, they were parking brakes because when they were designed cars didn't have a park function, they were manuals and without a parking brake the car would roll on an incline unless you left it in gear and sometimes it'd move anyway. That's also why you are supposed to crab your tires, or are you going to tell be they called it lobstering your tires before they ever called it crabbing.
not hard to prove at all. troll much? EMERGENCY BRAKE this was literally the first result from searching "emergency/parking brake in autos".
There's no point in arguing with Sniper, I think that he's only here to argue and not really add any helpful information. whistling
Most of his replies on here are only arguing but add nothing really useful to the discussion.
he's (maybe she's. or "it's") the same on every forum they post on. my post was to illustrate the fact, for the rest of the people in the thread, the facts on the emergency brake, as posted by an insurance company.
Re: Parking brake won't hold, what am I missing? [Re: Golden-Arm] #3080979
09/26/22 08:51 PM
09/26/22 08:51 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Yes, gloss right over the fact that your insurance company quote, lol, contains a glaring and factually incorrect claim that it reduces engine wear in the very first paragraph. You uncritically accept it because it supports your equally incorrect opinion of how the parking brake system functions.
Re: Parking brake won't hold, what am I missing? [Re: Sniper] #3080987
09/26/22 09:16 PM
09/26/22 09:16 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
And you obviously have no clue how an emergency system works.
Re: Parking brake won't hold, what am I missing? [Re: Sniper] #3080990
09/26/22 09:22 PM
09/26/22 09:22 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Parking brake or emergency brake??? Me, I think parking brake because it always took the Lone Ranger and Tonto to stop this when it was a runaway, especially with all of that horsepower. That little hand parking brake was not going to do anything, and I never saw it stop it when I was a kid so I knew not to count on it when I got my Road Runner in 1969. wink back to: catfight argue laugh2
Mike
Re: Parking brake won't hold, what am I missing? [Re: A12] #3080994
09/26/22 09:38 PM
09/26/22 09:38 PM
haha
Save the arguments for the important stuff, like proper pinion angle.
Re: Parking brake won't hold, what am I missing? [Re: Guitar Jones] #3081006
09/26/22 10:20 PM
09/26/22 10:20 PM
Tennessee
CUDASCOTT Offline
CUDASCOTT  Offline
Tennessee
haha
Yea what he said
Page 3 of 4 1 2 3 4
