rocker shafts for crane gold rockers
#3079349
09/21/22 04:13 PM
09/21/22 04:13 PM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
Is there any reason you couldn't run factory rocker shafts w/ a set of Crane gold roller rockers on a big block w/ a mild cam?
Re: rocker shafts for crane gold rockers
[Re: Cab_Burge]
#3079354
09/21/22 04:19 PM
09/21/22 04:19 PM
an8sec70cuda
Cab...I'm referring to the aluminum Crane gold rockers.
[Re: '72CudaRacer]
#3079397
09/21/22 07:06 PM
09/21/22 07:06 PM
Posts: 8,869 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Is there any reason you couldn't run factory rocker shafts w/ a set of Crane gold roller rockers on a big block w/ a mild cam? No reason why you "can't" but a few reasons why you "shouldn't" Stock shafts are thin. They will flex during use. They will also "pinch" as you torque them down - this can cause binding of the rockers Also, once pinched the rockers will be a [censored] to get off the shafts. The stock shafts never got a "finish" that would be satisfactory for the full contact of an aftermarket rocker so. as previously mentioned, galling is almost a certainty. Throw them in the trash and spend the $$ on a decent set of shafts.
[Re: Stanton]
#3079514
09/22/22 08:15 AM
09/22/22 08:15 AM
an8sec70cuda
OK, that makes sense since the stock rockers are so loose fitting on the shaft.
