Lokar Floor Shifter Question #3078476
09/18/22 03:25 PM
09/18/22 03:25 PM
Farmington Hills, MI
BPBP440 Offline OP
BPBP440  Offline OP
Putting my car back together 70 B-Body, 440/727. It utilizes a Lokar floor shifter. The previous owner installed it and used a combination of fitting to relocate the Trans Cooler Line around the linkage.
Has anyone else had to do this? Better solution?
Re: Lokar Floor Shifter Question [Re: BPBP440] #3078576
09/18/22 09:09 PM
09/18/22 09:09 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
I don't mean to be offensive but that looks like kluge and a problem waiting to happen when you least need it to. I would be finding a way to work around that even going back to factory linkage if needed. Why someone would choose to put one of those in a 70 b body is realcrazy IMO.
It doesn't help that I'm not overly fond of lokar's poorly engineered cr-p frown
more pic's may help beer
It appears if one removed the 2nd elbow and pipe nipple, then threaded the flared x 1/8 NPT fitting straight into the first elbow ( pointing it more forward) you would still have a kluge but a better one shruggy
Re: Lokar Floor Shifter Question [Re: TJP] #3078730
09/19/22 02:08 PM
09/19/22 02:08 PM
moparx Offline
moparx  Offline
not a fan of lokar "stuff" either.
it looks like the fittings need to be removed, then use a 90 degree 1/8npt male to 5/16 [maybe 1/4 ?] female tube fitting.
point it toward the front, then bend the output line to fit around the linkage in all positions it might encounter.
beer
Re: Lokar Floor Shifter Question [Re: moparx] #3078822
09/19/22 05:51 PM
09/19/22 05:51 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Also not a LoKar fan...
Re: Lokar Floor Shifter Question [Re: moparx] #3078859
09/19/22 08:59 PM
09/19/22 08:59 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
beer
Doesn't look like a 90 to tube will thread in without hitting the case frown
Re: Lokar Floor Shifter Question [Re: TJP] #3079008
09/20/22 11:46 AM
09/20/22 11:46 AM
moparx Offline
moparx  Offline
i think you are correct.
i just looked at a case, and it's too close for anything but the original fitting or a nipple to something else.
if a person had access to one of those tube benders that can do a tight 90 right at the fitting, that "might" work.
the best thing would be to scrap the lokar setup and start over. [just my opinion on what i would do]
beer
