I'd like to see the 7" with the radial. Though it may not need all that travel. An adjustable lower mount should get you there. You can run the shock compressed 5" Doug
Re: How to race on a poor track with drag radials
[Re: dvw]
#3070893 08/23/2208:41 PM08/23/2208:41 PM
Work with what you have now except...!!!Put pair of 125lb hypercoils on it!!! Like has been mentioned, adjust springs so you have about 1.5" of compressed travel 3.5" or more extension. If you do move the front of the ladder bar then you'll obviously have to correct the pinion angle...is it 'correct' now? A biased tire is probably the most forgiving, and put the biggest one you can fit currently.
[Re: HardcoreB]
#3071103 08/24/2203:15 PM08/24/2203:15 PM
... A biased tire is probably the most forgiving, and put the biggest one you can fit currently.
"Poor track" and "radial" don't typically go together. Maybe the newer "bracket" radials from M/T and Hoosier are more forgiving, but radials traditionally have been highly dependent upon track prep to work well.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3071118 08/24/2204:04 PM08/24/2204:04 PM
Yes true.....BUT depends on the power level and the car. My sons car (11.teens on motor) runs the same street or track, he beat a Red Eye Challenger pretty easily on the street.(295 radials) The Nova i posted the pic of, that car runs 9.30 at ANY track its been to. Im sure its borderline at some tracks, but it just flat out works. I cant recall a time that car has ever spun the tire. We had to take gear out of it to keep it off the bumper
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#3071126 08/24/2204:19 PM08/24/2204:19 PM
we do a lot of racing in F.A.S.T. factory appearing stock tire never full throttle off line, part throttle , dont floor it till second gear have gotten very consistent you will have to find sweet spot, we have cars running 9's with G60-15, have gone 11.0's with F70-14 360 duster
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: 440lebaron]
#3071136 08/24/2205:06 PM08/24/2205:06 PM
@Tony - The Hoosier 9x30 stocker radials I used to run on my '73 were the epitome of a radial that either dead-hooked or simply spun 'til ya' let up, which seemed to be the rep radials have had for years. My ET Street S/S appear to be better about "iffy" conditions -- on my slow-a$$ 1320, at least. When the '73 comes back, I'm gonna have a new learning curve to deal with.
@lebaron - I have AMAZING respect or the F.A.S.T. cars, but ya' gotta admit those aren't racing against a dial-in or an index where you need round-to-round consistency like w/ your new Stocker. BTW, I enjoy your progress reports on the new car.
[Re: Brad_Haak]
#3074567 09/05/2207:22 PM09/05/2207:22 PM
Scaled and balanced the the car and had some significantly better runs, Same front shock setting (in the middle ) Rear shocks (single adjustable) Changed 130 lb springs with preload of about 35%
Ladder bar at top measure at about 180% anti -squat. CHART at end of video
What did it run now compared to before? It looks like you are closer to 50% collapsed so you have room to go down in compression IF YOU NEED TO. It looks like it's working good! I would sort-out what you have now. Of course double adjustable are better but based on your incrementals we can surmise how much more there is left. GOOD WORK, CONGRATS!
Re: UPDATE! How to race on a poor track with drag radials
[Re: HardcoreB]
#3078380 09/18/2212:07 PM09/18/2212:07 PM
What did it run now compared to before? It looks like you are closer to 50% collapsed so you have room to go down in compression IF YOU NEED TO. It looks like it's working good! I would sort-out what you have now. Of course double adjustable are better but based on your incremental we can surmise how much more there is left. GOOD WORK, CONGRATS!
Thankyou HardcoreB
I was really wondering what improvements I may expect with a better shock and hope to get a guess from the Moparts group here...
