Re: '67 GTX goes 9.56 @ 137 [Re: Tig] #3077770
09/16/22 10:54 AM
09/16/22 10:54 AM
AndyF Offline OP
AndyF  Offline OP
That will happen if you go too tall. It also happens if you go too deep. Really depends on the car as well as the converter.
Re: '67 GTX goes 9.56 @ 137 [Re: AndyF] #3077801
09/16/22 12:27 PM
09/16/22 12:27 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
I really like that car! punkrocka
I looked at a '67 GTX many years ago and the only reason I passed on it was I didn't think I could put enough tire under it to make it hook well on the street. This was well before readily available soft-compound DOT tires, and it would have definitely been raced more on the street than the track at that time. whistling
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: '67 GTX goes 9.56 @ 137 [Re: Brad_Haak] #3077866
09/16/22 04:01 PM
09/16/22 04:01 PM
Chesterfield Twp. Mi.
John Burdine Online work
John Burdine  Online Work
One of the coolest cars on Moparts for sure.
Re: '67 GTX goes 9.56 @ 137 [Re: John Burdine] #3077868
09/16/22 04:11 PM
09/16/22 04:11 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Are they Torque Thrusts with beadlocks?
'63 Dodge 330
11.19 @ 121 mph
Re: '67 GTX goes 9.56 @ 137 [Re: GY3] #3077908
09/16/22 07:33 PM
09/16/22 07:33 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I believe he had them added to his Torque Thrusts last year.
Gus beer
64 Plymouth Savoy
Dana 60
Re: '67 GTX goes 9.56 @ 137 [Re: fourgearsavoy] #3077942
09/16/22 09:01 PM
09/16/22 09:01 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Fran, your GTX is hooking awesome! You have brought that car a long ways from the old days when you first got it into the 10's.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: '67 GTX goes 9.56 @ 137 [Re: Hemi_Joel] #3078047
09/17/22 10:51 AM
09/17/22 10:51 AM
Cleveland Ohio
10secGTX Offline
10secGTX  Offline
Cleveland Ohio
Thank You all for the kind words, This Forum and some of the Best Friends, helped me with this car. I have owned the car since 1986, and it will never be truly Done. just evolving,
Re: '67 GTX goes 9.56 @ 137 [Re: GY3] #3078048
09/17/22 10:52 AM
09/17/22 10:52 AM
Cleveland Ohio
10secGTX Offline
10secGTX  Offline
Cleveland Ohio
I sent the wheels to MACFAB Great people and its a single bead lock on the outside
Re: '67 GTX goes 9.56 @ 137 [Re: 10secGTX] #3078072
09/17/22 12:13 PM
09/17/22 12:13 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I figured that might be who did them. Our 275's are moving quite a bit on the wheels. We mark tire with a paint pen at the valvestem when new sets go on and it's crazy how much they move.
'63 Dodge 330
11.19 @ 121 mph
Re: '67 GTX goes 9.56 @ 137 [Re: GY3] #3078079
09/17/22 12:35 PM
09/17/22 12:35 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Awesome car, and those beadlocks on the Torq Thrusts are awesome!
Re: '67 GTX goes 9.56 @ 137 [Re: AndyF] #3078094
09/17/22 01:24 PM
09/17/22 01:24 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Looks like for a 28” tire(if that’s what he’s running) and 137-ish mph, along with the typical converter slip, 3.9’s seems right(7000-7200 trap rpm).
Re: '67 GTX goes 9.56 @ 137 [Re: fast68plymouth] #3078252
09/17/22 11:40 PM
09/17/22 11:40 PM
AndyF Offline OP
AndyF  Offline OP
I agree, those EZ heads nose over once the engine gets past 7000 rpm.
Re: '67 GTX goes 9.56 @ 137 [Re: AndyF] #3078383
09/18/22 12:10 PM
09/18/22 12:10 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Nice update Fran! I'd bet there is more MPH in it and a little more ET based on the incremetals. Do you have 330 and 660 and 1000ft ET/MPH?
Re: '67 GTX goes 9.56 @ 137 [Re: HardcoreB] #3079208
09/21/22 05:14 AM
09/21/22 05:14 AM
Cleveland Ohio
10secGTX Offline
10secGTX  Offline
Cleveland Ohio
Re: '67 GTX goes 9.56 @ 137 [Re: 10secGTX] #3079575
09/22/22 10:54 AM
09/22/22 10:54 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Not sure if you have O2 data but that might help point to some gains, probably air directed into the carb. I think there's some MPH in there but not much more ET. So, as long as it's safe fuel over the run I'd almost leave things alone and enjoy. You have it running well.
