Page 3 of 7 1 2 3 4 5 6 7
Re: Drag Week 2022 Who's in? [Re: Bad340fish] #3077384
09/15/22 01:02 AM
09/15/22 01:02 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
The challenge continues:
I got it put back together. It started. It ran while I was getting the timing set. It started out way too retarded and sneezed a couple times. Nothing leaked so far. Then it made a clunk and quit. It wouldn't restart.
I found that there's no spark
Then I found that the reason that there was no spark is that the distributor is not turning.
Then I found that the reason that the distributor is not turning is that the camshaft is not turning.
Cranking the motor with a valve cover off, one valve just starts to lift and then it falls back down and then it starts to lift again. I think it might have sheered off the key on the crank gear.
I have a funeral to go to tomorrow where I'll be busy all day, but Friday I'll pull the front cover off and see if I can get it fixed. Then we'll have to head out to drag week without any test & tune.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Drag Week 2022 Who's in? [Re: Bad340fish] #3077390
09/15/22 05:53 AM
09/15/22 05:53 AM
Taxes & Virus's R-US, NY
Dragula Online content OP
Dragula  Online Content OP
Originally Posted by Bad340fish
My boy and I got the car out for a 25ish mile drive. Everything seems pretty good, my new radiator and shroud combo isn't working as good as I hoped but its not bad, its just not better. Maybe the 35GPM water pump isn't enough? I would have to go remote to go with more flow but for now this is livable.
I am happy with how the car drove and everything I saw on the data log from the drive so I am going to pass on testing Friday night.
I will be moving to 20W50 VR1. These lifters that pressure feed the rollers move ALOT of oil. I am down about 10-20PSI hot.
I love this blue because the car hasn't been washed since April, its dusty and has slimy hand prints all over it. But it photographs like its clean.
For radiators, I just switched to a Griffin Thermal Universal Rad with 1.25 tubes.....What a difference over the BeCool that cost twice as much but had 1.0 tubes. I do run the 55gallon/hr Mezeire pump with a set of Custom fans and shroud...All of it helped.
Re: Drag Week 2022 Who's in? [Re: Dragula] #3077417
09/15/22 08:38 AM
09/15/22 08:38 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
This morning 2 questions come up about the Hemi. Why did it break? Could .005 off of the head have caused a piston to valve collision that broke the cam drive? Could cranking it with the cam not turning have caused an additional piston to valve collision?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Drag Week 2022 Who's in? [Re: Hemi_Joel] #3077484
09/15/22 12:12 PM
09/15/22 12:12 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Unfortunately, you already know the answers to those questions.
Hope it turns out favorably for you.
Re: Drag Week 2022 Who's in? [Re: TRENDZ] #3077587
09/15/22 06:03 PM
09/15/22 06:03 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
x2. Especially the 2nd question. I'm so sorry, this is heartbreaking!
I hope it's just the keyway sheared off and the valves aren't bent.
Re: Drag Week 2022 Who's in? [Re: Blusmbl] #3077645
09/15/22 08:32 PM
09/15/22 08:32 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I'm going to dig into it tonight but I have a feeling it's going to be more of a post mortem than a repair.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Drag Week 2022 Who's in? [Re: Hemi_Joel] #3077851
09/16/22 03:23 PM
09/16/22 03:23 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
My WAG is....... the cam bolt loosened up, the top gear was shucking around, and that movement allowed the key to shear off ....... especially if it’s an offset key.
Time to start loading up the GTX.
Re: Drag Week 2022 Who's in? [Re: fast68plymouth] #3077861
09/16/22 03:53 PM
09/16/22 03:53 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
The key on the cam and the key on the crankshafter both sheared off. The borescope found no witness marks on the Pistons. I'm working on trying to get the crank gear off right now. I think the sheared off key is binding against the crankshaft and it's really stuck on there.
Perhaps when I reassembled the head, one of the spring locaters on the heads did not get seated properly and caused coil bind? Just a guess?
I have over half of the push rods out. What I need to do is turn the camshaft enough to get the rest of the pushrods out, then do a leak down test on each cylinder to see if I have any bent valves.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Drag Week 2022 Who's in? [Re: Hemi_Joel] #3077869
09/16/22 04:13 PM
09/16/22 04:13 PM
So. Burlington, Vt.
So. Burlington, Vt.
Wow....... that is a first for me.
Both keys sheared off.
Re: Drag Week 2022 Who's in? [Re: fast68plymouth] #3077872
09/16/22 04:30 PM
09/16/22 04:30 PM
W. Pa
U
usp4u Offline
usp4u  Offline
U
W. Pa
Wow those threads look hammered
Re: Drag Week 2022 Who's in? [Re: usp4u] #3077890
09/16/22 05:43 PM
09/16/22 05:43 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Well it turns out I was mistaken. The crankshaft key was not sheared. Only the camshaft key was broke. So I pulled the crank gear off for nothing. Some of the ugliness of those threads in the crank is residual loctite. I just got back from town, had to run for a woodruff key. Hopefully I'll know something pretty soon. Now I need to pull out my paperwork and figure out how I time this gear drive again.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Drag Week 2022 Who's in? [Re: Hemi_Joel] #3077896
09/16/22 05:59 PM
09/16/22 05:59 PM
So. Burlington, Vt.
So. Burlington, Vt.
Was the cam gear bolt still fully torqued?
When the cam gear is seated against the register on the cam, does the cam gear stand proud of the nose of cam?
Re: Drag Week 2022 Who's in? [Re: fast68plymouth] #3077919
09/16/22 08:14 PM
09/16/22 08:14 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Well, I'm out for Drag Week 2022.
The leak down test shows bent valves, plus the#1 intake adjuster is broke. I'm very disappointed. whiney
This weekend I'll tear it apart, try to figure out what happened, and start getting it ready for next year.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Drag Week 2022 Who's in? [Re: fast68plymouth] #3077931
09/16/22 08:31 PM
09/16/22 08:31 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I'm embarassed to say that there was no bolt holding the cam gear hub to the cam. Just a light press fit. I must have forgot to install it in 2020 when I put the gear drive in. Amazing that it worked. The hub had not moved on the cam, it was still flush.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Drag Week 2022 Who's in? [Re: Hemi_Joel] #3077945
09/16/22 09:05 PM
09/16/22 09:05 PM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
Taking the GTX?
Re: Drag Week 2022 Who's in? [Re: ksj] #3077949
09/16/22 09:16 PM
09/16/22 09:16 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Originally Posted by ksj
Taking the GTX?
Probably not. The red FAST GTX needs a clutch and some other stuff, and I'm too tuckered out to spend all night tonight on it. Plus it's not at all dialed in for Drag Week.
I don't really want to bring the blue GTX convert again, I already made 2 parade laps of drag week with it in '15 and '16. I thought about going in the '57 Desoto, but even though it was fast in 1957, by todays drag week standards it is too slow. They don't want 16 second cars there.
Last year, I read a quote somewhere, "If you stay ready, you never have to get ready" I liked that and set about to get all my stuff ready so I could be ready and stay ready. But so many things went awry in the last 12 months, that I didn't get anything completely ready to my satisfaction despite a lot of effort. Hopefully by next year, all my stuff will be ready so I can stay ready.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Drag Week 2022 Who's in? [Re: Hemi_Joel] #3077986
09/16/22 11:16 PM
09/16/22 11:16 PM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
Taking the GTX?
Re: Drag Week 2022 Who's in? [Re: ksj] #3077987
09/16/22 11:17 PM
09/16/22 11:17 PM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
Understood. Game has passed me by and I try and go for a few days. Last time was 2019. 2023 for you and the monkey LOL
Re: Drag Week 2022 Who's in? [Re: ksj] #3078037
09/17/22 10:11 AM
09/17/22 10:11 AM
Damn that sucks.....If you were closer, I would lend you my car...Its almost Drag Week ready.....Just needs the roll bar made intro a full cage, and she is legal for the ET it runs.
Re: Drag Week 2022 Who's in? [Re: Hemi_Joel] #3078064
09/17/22 11:42 AM
09/17/22 11:42 AM
So. Burlington, Vt.
So. Burlington, Vt.
I guess the silver lining is it didn’t happen during drag week........... at a point when you were as far away from the trailer as you could be.
