Re: 69 Dart Fenders on a 67 Dart?
[Re: patosmith]
#3078606
09/18/22 11:45 PM
09/18/22 11:45 PM
Posts: 43,626 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
68 fenders are even further out than 67 or 69, they are by themselves. There were lots of differences in the headlight bucket area for all three years. I bought an 11,000 mile 69 Dart from the original little old lady owner and something seemed off on the front. When I got it home I noticed it had a 67 fender on the passenger side, the 69 headlight bezel was off by about an inch, so I am sure visa versa would be the same. I have a pair of each fenders, grilles, and headlight bezels laying around, I need to bolt them all on a spare body I have and see what the real differences are...
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#3078661
09/19/22 10:02 AM
09/19/22 10:02 AM
Posts: 12,293 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Not that long ago, I was fixing up a '68 Dart 270. The right side had been hit and fixed long ago. The right fender had been replaced apparently with a new one and the Chrysler part number was still visible inside the fender. Now clearly the fender was not originally built for a '68. The headlight bucket was moved/replaced. And the top of the fender above the headlight was different than the '68s. I have always wondered if it came that way from Mopar or had been modified at a shop.
Master, again and still
[Re: demon]
#3079661
09/22/22 03:01 PM
09/22/22 03:01 PM
Posts: 19,629 north of coder
moparx
i was under the impression you could the complete nose [67, 68, 69, 70, etc] assembly on all darts up to around 73 or so ? in other words, the panels would bolt on, but in order to fit and look correct, you need to use all the like year parts. [fenders, hood, grille, etc.]
[Re: moparx]
#3079753
09/22/22 08:41 PM
09/22/22 08:41 PM
Rhinodart
Rhinotruck
Rhinotruck
i was under the impression you could the complete nose [67, 68, 69, 70, etc] assembly on all darts up to around 73 or so ? in other words, the panels would bolt on, but in order to fit and look correct, you need to use all the like year parts. [fenders, hood, grille, etc.] Yes, entire doghouses are interchangeable except that in late 69 there were tabs added for the upcoming lower valance for the 70-72 Dart and Demon on the lower core support, if your body does not have those tabs then you have to figure out how to mount the valance...
A-Body's RULE!
