Doube adjustable shocks Viking performance shocks?? #3075138
09/07/22 01:54 PM
09/07/22 01:54 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
Been doing some research for double or triple adjustable shocks for the rear of my car
Been looking at Afco and VIKING
It looks like VIKING has user adjustable valving for extra opportunities for future adjustment
Anyone used Viking?
Is anyone a dealer?
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Doube adjustable shocks Viking performance shocks?? [Re: Kam*Kuda] #3075142
09/07/22 02:05 PM
09/07/22 02:05 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
I have Vikings on my cuda and I like them. I'm sure there are better shocks out there, but they sure do cost a LOT more than the Vikings do. I've been pleased w/ mine.
If you make a lot of power, talk w/ them about the valving packages they have. up
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Doube adjustable shocks Viking performance shocks?? [Re: an8sec70cuda] #3075145
09/07/22 02:10 PM
09/07/22 02:10 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I have them for the back of the '63. Need to get some DA fronts.
I haven't had a lot of time to test with them and have only run a few passes. Between the heat this summer and no prep available, I haven't gotten to the track.
They seem to do what they're supposed to and ride really smooth on the street on lower settings.
'63 Dodge 330
11.19 @ 121 mph
Re: Doube adjustable shocks Viking performance shocks?? [Re: GY3] #3075182
09/07/22 03:08 PM
09/07/22 03:08 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
You will probably want to get the "Crusader" series that has some different valving options like Chip mentioned. I have the regular DA shocks front and rear on mine and I have been happy with them. I am running out of adjustment on the extension part of the rears but they have been worth the money and if I need to I will be going to the Crusader series. I have a few things to try first, like preload on the cal tracks and standing the shocks up more straight from the stock location.
68 Barracuda Formula S 340
Re: Doube adjustable shocks Viking performance shocks?? [Re: Bad340fish] #3075188
09/07/22 03:26 PM
09/07/22 03:26 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Viking has a new series of Double-Adjustable shocks... they call them BISERKERS. Call and discuss.. I've found them very helpful... I have these new Biserkers on the rear of my Challenger... and they also have most of their shocks in different lengths for your needs (my car is lowered)... or else they will make them to your needs/specs.
Re: Doube adjustable shocks Viking performance shocks?? [Re: Mopar Mitch] #3075234
09/07/22 05:37 PM
09/07/22 05:37 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
No experience with Vikings. They seem to have a good rep. I have seen guys beat on QA1s pretty hard and they seem to hold up fairly well considering.
I like AFCOs. They make nice stuff and many custom shops use their components.
Admittedly, I'm a shock snob, but not everyone needs $4000 (or more) worth of shocks on their car. But it is easy to get outside the window of what a shelf shock can do with the power, suspensions and tires available today.
Re: Doube adjustable shocks Viking performance shocks?? [Re: CMcAllister] #3075298
09/07/22 08:05 PM
09/07/22 08:05 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Like them a lot. I have them on both of my cars.
Re: Doube adjustable shocks Viking performance shocks?? [Re: Dragula] #3075308
09/07/22 08:37 PM
09/07/22 08:37 PM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
Put crusaders on my 10:00 bb a body two years ago . Upgraded the rears to stiffer valving . Good money spent as far as my budget.
Re: Doube adjustable shocks Viking performance shocks?? [Re: Wirenut] #3075351
09/07/22 10:09 PM
09/07/22 10:09 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
I've considered Viking Crusaders as a rear damper upgrade from my archaic Rancho 5-ways. I'd like to hear more details about what valving and damping settings people who are running them successfully use.
FWIW, my application uses CalTracs, mono-leaf springs and DOT drag radials.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Doube adjustable shocks Viking performance shocks?? [Re: Brad_Haak] #3075363
09/07/22 10:41 PM
09/07/22 10:41 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
definately an upgrade . i went from rancho 9 ways to crusaders as my HP went up . I have only run radials on my Plymouth .
I have not needed to upgrade valving , though it may help . I really need them on the front but Aussie peso kills that .
I have comp on #10 , ext #5 , both from loose.
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Doube adjustable shocks Viking performance shocks?? [Re: Kam*Kuda] #3077734
09/16/22 08:23 AM
09/16/22 08:23 AM
Hamilton,Ont
72chrgrally Offline
72chrgrally  Offline
Hamilton,Ont
I have Crusaders all around on mine. I had to buy through a Canadian dealer. So far so good.
Photobucket sucks
Re: Doube adjustable shocks Viking performance shocks?? [Re: 72chrgrally] #3077737
09/16/22 09:02 AM
09/16/22 09:02 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
I just bought the regular DA fronts and Crusader DA rears for my car, they're running at about a 5 week lead time right now. Not sure I'll get to try them before the tracks close here, but I'm excited to test with them as soon as I can.
