Re: '67 GTX goes 9.56 @ 137
[Re: AndyF]
#3077801
09/16/22 12:27 PM
09/16/22 12:27 PM
Posts: 1,118 Loudoun County, VA
Brad_Haak
Loudoun County, VA
I really like that car! I looked at a '67 GTX many years ago and the only reason I passed on it was I didn't think I could put enough tire under it to make it hook well on the street. This was well before readily available soft-compound DOT tires, and it would have definitely been raced more on the street than the track at that time.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: John Burdine]
#3077868
09/16/22 04:11 PM
09/16/22 04:11 PM
Posts: 4,669 Wichita
GY3
Wichita
Are they Torque Thrusts with beadlocks?
[Re: GY3]
#3077908
09/16/22 07:33 PM
09/16/22 07:33 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
Are they Torque Thrusts with beadlocks? I believe he had them added to his Torque Thrusts last year. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#3077942
09/16/22 09:01 PM
09/16/22 09:01 PM
Posts: 7,480 Minnesota
Hemi_Joel
Minnesota
Fran, your GTX is hooking awesome! You have brought that car a long ways from the old days when you first got it into the 10's.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#3078047
09/17/22 10:51 AM
09/17/22 10:51 AM
Posts: 2,117 Cleveland Ohio
10secGTX
Cleveland Ohio
Fran, your GTX is hooking awesome! You have brought that car a long ways from the old days when you first got it into the 10's. Thank You all for the kind words, This Forum and some of the Best Friends, helped me with this car. I have owned the car since 1986, and it will never be truly Done. just evolving,
[Re: GY3]
#3078048
09/17/22 10:52 AM
09/17/22 10:52 AM
10secGTX
Cleveland Ohio
Are they Torque Thrusts with beadlocks? I sent the wheels to MACFAB Great people and its a single bead lock on the outside
[Re: 10secGTX]
#3078072
09/17/22 12:13 PM
09/17/22 12:13 PM
GY3
Wichita
Are they Torque Thrusts with beadlocks? I sent the wheels to MACFAB Great people and its a single bead lock on the outside I figured that might be who did them. Our 275's are moving quite a bit on the wheels. We mark tire with a paint pen at the valvestem when new sets go on and it's crazy how much they move.
[Re: GY3]
#3078079
09/17/22 12:35 PM
09/17/22 12:35 PM
Posts: 8,163 Plymouth, MI
Blusmbl
Plymouth, MI
Awesome car, and those beadlocks on the Torq Thrusts are awesome!
[Re: AndyF]
#3078094
09/17/22 01:24 PM
09/17/22 01:24 PM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Looks like for a 28” tire(if that’s what he’s running) and 137-ish mph, along with the typical converter slip, 3.9’s seems right(7000-7200 trap rpm).
[Re: fast68plymouth]
#3078252
09/17/22 11:40 PM
09/17/22 11:40 PM
Posts: 31,002 Oregon
AndyF
Looks like for a 28” tire(if that’s what he’s running) and 137-ish mph, along with the typical converter slip, 3.9’s seems right(7000-7200 trap rpm). I agree, those EZ heads nose over once the engine gets past 7000 rpm.
