Bell housing bolts #3077359
09/14/22 10:44 PM
09/14/22 10:44 PM
New Hampshire, USA
O
oldiron Offline OP
oldiron  Offline OP
O
New Hampshire, USA
Since I'm getting tired and need a break, does anyone actually torque the bell to clock bolts or just make them german tight? wrench
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: Bell housing bolts [Re: oldiron] #3077371
09/14/22 11:33 PM
09/14/22 11:33 PM
Rogue River, OR
Jeremiah Online work
Jeremiah  Online Work
Rogue River, OR
I made it a habit after cracking a bell years ago becaise the bolts were not Austrian tight. It makes sense with the safety can given the intended use. I loctite eveything, especially with a motor plate.
"7. Position your Lakewood Bellhousing over the flywheel/
clutch assembly and slide onto dowel pins in engine
block. Fasten the bellhousing to the engine block using
the 3/8”-16 x 1” (35 ft lbs of torque) and 1/2” bolts (100-
110 ft lbs) grade 8 bolts supplied. Secure the blockplate
to the bellhousing using the supplied grade 8 fasteners
installed in the order shown on the illustration."
I go 45 ft-lbs on the 3/8 and 85 on the two that go in from the front. Might have used# those from the manual but I can't remember
Re: Bell housing bolts [Re: oldiron] #3077418
09/15/22 08:56 AM
09/15/22 08:56 AM
an8sec70cuda Offline
Just tight here, no torque wrench. I don't use loctite on them either. To each their own...do what works for you. up
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Bell housing bolts [Re: an8sec70cuda] #3077427
09/15/22 09:17 AM
09/15/22 09:17 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
My bellhousing has to go on after installing the engine. I couldn't get a torque wrench on most of the bolts if I tried. Trans to bell is even worse on the new combo.
Jeff
69 GTX 68 Road Runner
Re: Bell housing bolts [Re: an8sec70cuda] #3077430
09/15/22 09:23 AM
09/15/22 09:23 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Years ago I bought the ARP bellhousing stud kit and I just torque the 3/8 studs to 50# and the 7/16 bolts to 80# even when I'm just setting it up twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Bell housing bolts [Re: oldiron] #3077511
09/15/22 01:07 PM
09/15/22 01:07 PM
Cab_Burge Online work
Cab_Burge  Online Work
I have never torque them, hand tight with a medium length wrench wrench grin
It can't hurt to torque them so do that if you can up
