Dodge Aspen parts #3075877
09/09/22 07:12 PM
09/09/22 07:12 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
I think this might be my first post in the restoration forum and may be the first Aspen post in here also but I just bought a nice survivor 79 aspen wagon and wanted to fix it up just a little before I hand it over to the wife. It has sat since 2006 and with nothing more than gas in the tank and a shot of either in the carb it fired right up and is rnning and driving but the brake pedal is a bit sticky...
First off where can I get a bright red cardboard headliner?
Also is there a way to pull the door panels off without damaging them to clean and lube up the window mechanisms?
Probably gonna have a lot more other questions...
Re: Dodge Aspen parts [Re: HotRodDave] #3076510
09/12/22 10:13 AM
09/12/22 10:13 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
You might want to join this forum :
https://www.forfmjbodiesonly.com/classicmopar/
Probably more there to answer your questions, etc . . .
Good luck
Cheers,
Mark
Re: Dodge Aspen parts [Re: a12rag] #3077410
09/15/22 08:18 AM
09/15/22 08:18 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Nobody sells the replacement headliner. Good used is usually your only choice. You will find that many parts for the volare aspen are not being reproduced or available. The door panels just have the standard door panel spring type clips around the ends and they need to be gently pried off between the clip and the metal part on the door. You can use a door panel removal tool that they sell at harbor freight. Some people have repaired the headliners and recovered with material. The warped ones can be worked back in shape with some work.
