Bell housing bolts
#3077359
09/14/22 10:44 PM
09/14/22 10:44 PM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
Since I'm getting tired and need a break, does anyone actually torque the bell to clock bolts or just make them german tight?
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: Bell housing bolts
[Re: oldiron]
#3077371
09/14/22 11:33 PM
09/14/22 11:33 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
I made it a habit after cracking a bell years ago becaise the bolts were not Austrian tight. It makes sense with the safety can given the intended use. I loctite eveything, especially with a motor plate.
"7. Position your Lakewood Bellhousing over the flywheel/ clutch assembly and slide onto dowel pins in engine block. Fasten the bellhousing to the engine block using the 3/8”-16 x 1” (35 ft lbs of torque) and 1/2” bolts (100- 110 ft lbs) grade 8 bolts supplied. Secure the blockplate to the bellhousing using the supplied grade 8 fasteners installed in the order shown on the illustration."
I go 45 ft-lbs on the 3/8 and 85 on the two that go in from the front. Might have used# those from the manual but I can't remember
[Re: oldiron]
#3077418
09/15/22 08:56 AM
09/15/22 08:56 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
Just tight here, no torque wrench. I don't use loctite on them either. To each their own...do what works for you.
[Re: an8sec70cuda]
#3077427
09/15/22 09:17 AM
09/15/22 09:17 AM
Posts: 10,044 MN
JERICOGTX
MN
My bellhousing has to go on after installing the engine. I couldn't get a torque wrench on most of the bolts if I tried. Trans to bell is even worse on the new combo.
Jeff
69 GTX
68 Road Runner
