Distributor Shaft Collar ?? #3076556
09/12/22 12:53 PM
09/12/22 12:53 PM
Ohio
B5TA Offline OP
B5TA  Offline OP
Ohio
So what are your thoughts about using a locking collar on the distributor shat above the intermediate shaft ??? Thanks, Kevin
Re: Distributor Shaft Collar ?? [Re: B5TA] #3076562
09/12/22 01:01 PM
09/12/22 01:01 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
People have been doing that for a long time.
Re: Distributor Shaft Collar ?? [Re: Sniper] #3076589
09/12/22 01:45 PM
09/12/22 01:45 PM
moparx Offline
moparx  Offline
cheap to buy at your local hardware store [Ace Hardware at the end of my block has them. up] or home improvement store.
beer
Re: Distributor Shaft Collar ?? [Re: moparx] #3076652
09/12/22 04:58 PM
09/12/22 04:58 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
not needed on B-RB, cam forces shaft/gear down, unless your warred about spark scatter when letting off gas
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Distributor Shaft Collar ?? [Re: 440lebaron] #3076655
09/12/22 05:15 PM
09/12/22 05:15 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
If you want to increase or decrease the play in the shaft, buy the Hillman nylon collar and drill it for the clearance you want. shruggy
'63 Dodge 330
11.19 @ 121 mph
Re: Distributor Shaft Collar ?? [Re: GY3] #3076674
09/12/22 06:22 PM
09/12/22 06:22 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
The idea of the locking collar is more to keep the intermediate shaft in place saving from timming jumping more than dist axial play
Re: Distributor Shaft Collar ?? [Re: NachoRT74] #3076676
09/12/22 06:38 PM
09/12/22 06:38 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i graduated from the collar nonsense a couple of decades ago. ironically it took a chevy guy to explain to me how the helix on the intermediate gear worked. the thrust is down not up. i have made shims to take end play out of the shaft. if you have erratic timing more likely than not the intermediate shat bushing is wore out.
Re: Distributor Shaft Collar ?? [Re: B5TA] #3076681
09/12/22 06:51 PM
09/12/22 06:51 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I have always used a piece of hydraulic hose just long enough to keep a little pressure between the 2 shafts. May not help anything, but it can't hurt either.
Master, again and still
Re: Distributor Shaft Collar ?? [Re: DaveRS23] #3076706
09/12/22 07:47 PM
09/12/22 07:47 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I bought some metal collars years ago from a stock racer.
Abe Lincoln
Re: Distributor Shaft Collar ?? [Re: dart4forte] #3076843
09/13/22 09:58 AM
09/13/22 09:58 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Slick idea on the hose, Dave. Much easier fix than fiddling with a collar.
Joe
Re: Distributor Shaft Collar ?? [Re: jlatessa] #3076897
09/13/22 12:13 PM
09/13/22 12:13 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Thank you.
