Dana 60 spring perch bending #3076443
09/12/22 01:14 AM
09/12/22 01:14 AM
Canada
Cape Offline OP
Cape  Offline OP
Canada
Hey! What’s everyone doing to strengthen the spring perches? I was at the track yesterday and after a couple hard launches I ended up splitting the yoke in half and making the perches look like a banana. There’s 2 shims under the perches for pinion angle , the u bolts are bent because the whole housing shifted forward 1/2 inch. All 8 wheel studs are bent and 1 axle has twisted splines. It’s a strange 60 as well. It’s a 69 charger 478 hemi stick car it launches hard and still in the breaking the clutch in steps. Im also dialing everything in as it’s a new combo. Any help would be great. Thanks.
Re: Dana 60 spring perch bending [Re: Cape] #3076445
09/12/22 01:27 AM
09/12/22 01:27 AM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
This was a common problem back in the 70's on Drag cars.
The fix was to weld a brace onto the back of the spring perches.
Use at least 1/4 inch piece of flat plate to the back of the spring perch to the axle housing.
Make sure the perch is flat before you weld it up.
Good Luck
Old Geezer Racing
Re: Dana 60 spring perch bending [Re: Cape] #3076447
09/12/22 01:32 AM
09/12/22 01:32 AM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Sorry, I forgot to add, for the u bolts, you can go to NAPA and they should have an assortment of truck u bolts that are thicker.
(Be sure to measure the inside dimensions, so the new u bolts fit tight to the housing).
You will have to open up the u bolt holes in the shock plate, but you will not have any more issues with the u bolts stretching.
Old Geezer Racing
Re: Dana 60 spring perch bending [Re: SCATPACK 1] #3076455
09/12/22 04:59 AM
09/12/22 04:59 AM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
Try the Calvert racing heavy duty axle perches. about $50 a pair.
Re: Dana 60 spring perch bending [Re: 572B1] #3076495
09/12/22 09:05 AM
09/12/22 09:05 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
x2; I had Strange use them for peace of mind when they built my Challenger's S-60
Not sure if either of these pics show enough to make sense, but the Calvert perches are nicely boxed in, not simply "heavy duty" versions of a standard style
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Dana 60 spring perch bending [Re: Brad_Haak] #3076497
09/12/22 09:24 AM
09/12/22 09:24 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Using stock perches,than reinforcement is a good idea.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Dana 60 spring perch bending [Re: 572B1] #3076544
09/12/22 12:27 PM
09/12/22 12:27 PM
oregon
greendart408 Offline
oregon
This...... Far superior, and the hole is the correct size too.
Re: Dana 60 spring perch bending [Re: greendart408] #3076545
09/12/22 12:31 PM
09/12/22 12:31 PM
Canada
Cape Offline OP
Cape  Offline OP
Canada
Ok thanks. That’s a great idea. Has anyone ever tried the ones from smith racecraft? There a square perch that welds to the same location as the stock perches but they eliminate using U bolts. I was wondering how they would work. Thanks.
Re: Dana 60 spring perch bending [Re: hemi-itis] #3076561
09/12/22 01:00 PM
09/12/22 01:00 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Yep, this is what I did for the same problem.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Dana 60 spring perch bending [Re: Cape] #3076603
09/12/22 02:14 PM
09/12/22 02:14 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I Imagine they work well, but you had better trust whoever welds them up to do a good job since the u bolts are not there to hold it all together should something come loose.
68 Barracuda Formula S 340
Re: Dana 60 spring perch bending [Re: Cape] #3076816
09/13/22 08:29 AM
09/13/22 08:29 AM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
Had no issues with the Calvert ones but JFI we have bent up some cheap, hollow, lowering blocks up
Re: Dana 60 spring perch bending [Re: Cape] #3077090
09/13/22 11:10 PM
09/13/22 11:10 PM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
Like mentioned above - I also use heavy duty perches and box them in. I use Dr. Diff perches ($15/set) then blend in plates to the ends for a clean look. I’m not a fan of the Assassin bolt from underneath perches. There’s too much leverage pulling in too many directions for my liking.
Here’s a couple pictures of one I’m building now for an A-Body:
