Re: Dana 60 spring perch bending
[Re: Cape]
#3076445
09/12/22 12:27 AM
09/12/22 12:27 AM
Posts: 1,509 TN
SCATPACK 1
TN
This was a common problem back in the 70's on Drag cars. The fix was to weld a brace onto the back of the spring perches. Use at least 1/4 inch piece of flat plate to the back of the spring perch to the axle housing. Make sure the perch is flat before you weld it up. Good Luck
Old Geezer Racing
[Re: Cape]
#3076447
09/12/22 12:32 AM
09/12/22 12:32 AM
Posts: 1,509 TN
SCATPACK 1
TN
Sorry, I forgot to add, for the u bolts, you can go to NAPA and they should have an assortment of truck u bolts that are thicker. (Be sure to measure the inside dimensions, so the new u bolts fit tight to the housing). You will have to open up the u bolt holes in the shock plate, but you will not have any more issues with the u bolts stretching.
Old Geezer Racing
[Re: 572B1]
#3076495
09/12/22 08:05 AM
09/12/22 08:05 AM
Posts: 1,486 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Try the Calvert racing heavy duty axle perches. about $50 a pair. x2; I had Strange use them for peace of mind when they built my Challenger's S-60 Not sure if either of these pics show enough to make sense, but the Calvert perches are nicely boxed in, not simply "heavy duty" versions of a standard style
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: 572B1]
#3076544
09/12/22 11:27 AM
09/12/22 11:27 AM
Posts: 1,080 oregon
greendart408
oregon
Try the Calvert racing heavy duty axle perches. about $50 a pair. This...... Far superior, and the hole is the correct size too.
[Re: hemi-itis]
#3076561
09/12/22 12:00 PM
09/12/22 12:00 PM
Posts: 4,027 South Park, Pa.
68LAR
South Park, Pa.
Using stock perches,than reinforcement is a good idea. Yep, this is what I did for the same problem.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: Cape]
#3076603
09/12/22 01:14 PM
09/12/22 01:14 PM
Posts: 8,136 Tulsa OK
Bad340fish
Tulsa OK
Ok thanks. That’s a great idea. Has anyone ever tried the ones from smith racecraft? There a square perch that welds to the same location as the stock perches but they eliminate using U bolts. I was wondering how they would work. Thanks. I Imagine they work well, but you had better trust whoever welds them up to do a good job since the u bolts are not there to hold it all together should something come loose.
68 Barracuda Formula S 340
[Re: Cape]
#3076816
09/13/22 07:29 AM
09/13/22 07:29 AM
Posts: 3,031 A shed in England
Tig
A shed in England
Had no issues with the Calvert ones but JFI we have bent up some cheap, hollow, lowering blocks ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
