Page 1 of 4 1 2 3 4
battery draining. Can't find the draw #3075560
09/08/22 05:03 PM
09/08/22 05:03 PM
Canada
demon Offline OP
demon  Offline OP
Canada
Working on a 78 Chrysler LeBaron. It's a low mileage car, absolutely stock and untouched, other than it has had an electronic ignition conversion to eliminate the Lean burn system.
So the issue is:
The battery will go dead in a day or so.
Brand new battery.
With the key off, doors and trunk closed, and checked to make sure no lights are on.
I pulled off the negative cable, and put a test light between the negative battery post, and the negative cable. The test light is bright.
I then pulled every fuse out one by one, and no change. Test light still on.
Disconnected various items such as alternator, electronic control box, wiper motor, power seat, and still no change.
Anyone have an idea as to what is drawing power?
Re: battery draining. Can't find the draw [Re: demon] #3075562
09/08/22 05:07 PM
09/08/22 05:07 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Years ago I had a similar issue. Turns out I put new trunk weatherstripping on and it held the trunk lid up enough to allow the light to remain on. Unless you get in the trunk and have someone shut it it's real hard to tell. I guess you could pull teh bulb and see if the battery drains.
Re: battery draining. Can't find the draw [Re: Sniper] #3075574
09/08/22 05:58 PM
09/08/22 05:58 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Check the dome light and the glove box light and the clock if equiped.
Re: battery draining. Can't find the draw [Re: Sniper] #3075576
09/08/22 06:24 PM
09/08/22 06:24 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
I have a 64 Falcon that has trunk light with a "mercury" type switch - switch was bad and would keep light on . . . would try above for sure
Re: battery draining. Can't find the draw [Re: a12rag] #3075577
09/08/22 06:32 PM
09/08/22 06:32 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Disconnect the alt.leads & see it could be shorted.
Re: battery draining. Can't find the draw [Re: demon] #3075591
09/08/22 07:05 PM
09/08/22 07:05 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Just a suggestion...
Pop off each bulkhead connector, 1 by 1....
See if the light goes OFF..
This may point U in the right direction..
Just my $0.02.... wink
Re: battery draining. Can't find the draw [Re: 71GTX471] #3075594
09/08/22 07:31 PM
09/08/22 07:31 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
This. My '89 Diplomat fought me with this and it was the alternator.
Facts are stubborn things.
Re: battery draining. Can't find the draw [Re: larrymopar360] #3075621
09/08/22 08:49 PM
09/08/22 08:49 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Read ....He has disconnected the alternator.
Re: battery draining. Can't find the draw [Re: NITROUSN] #3075626
09/08/22 09:05 PM
09/08/22 09:05 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
My bad missed that.
Re: battery draining. Can't find the draw [Re: NITROUSN] #3075628
09/08/22 09:08 PM
09/08/22 09:08 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Might be worth checking the fusible links in the harness.
Re: battery draining. Can't find the draw [Re: demon] #3075649
09/08/22 09:58 PM
09/08/22 09:58 PM
N
NITROUSN Offline
NITROUSN  Offline
N
One over looked item is the key light and relay. Something should be warm. What is the history and when did this start? Get it in a dark garage or go out at late night when it is very dark and look for something lit.
Re: battery draining. Can't find the draw [Re: NITROUSN] #3075655
09/08/22 10:27 PM
09/08/22 10:27 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Converted ignition? Been a while but doesn't that have a ballast hook in? Where is that getting it's power?
Re: battery draining. Can't find the draw [Re: demon] #3075657
09/08/22 10:36 PM
09/08/22 10:36 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I had one years ago on 63? T bird. Couldn't find it. It had the older analog clock that had points. When the clock spring needed to wound the points would close, wind the spring and the points would open. OK but this clock wasn't working so I blew by it. After chasing my tail for a few hours a buddy suggested disconnecting the clock. I said why? it's not working whistling
Well lo and behold the points were stuck shut, which overwound the spring until it broke, so the clock motor was running all the time. But you couldn't hear it and I ASSumed it was not the issue.
might try the bulkheads as suggested as it might narrow it down. I would start with the wiper motor harness.
It has to be something that is hot all the time and not fused by the fuse box wink
A schematic would be very helpful as well
Keep us posted wink
Re: battery draining. Can't find the draw [Re: TJP] #3075661
09/08/22 10:43 PM
09/08/22 10:43 PM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
Trying to shotgun electrical problems usually never ends well. Get a wiring diagram for your car. Based on that, start removing components one by one until the problem is found. I've been through this more than once and this typically has worked best for me.
Re: battery draining. Can't find the draw [Re: demon] #3075667
09/08/22 11:28 PM
09/08/22 11:28 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
So the issue is:
Brand new battery.
Some circuits are not fused: HL,park,etc. Focus on those type circuits.
Re: battery draining. Can't find the draw [Re: PhillyRag] #3075685
09/09/22 02:05 AM
09/09/22 02:05 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Just have to keep disconnecting stuff until it disappears. Relays, Connections. As stated, firewall connections to try to isolate it.
Re: battery draining. Can't find the draw [Re: 6PakBee] #3075687
09/09/22 03:46 AM
09/09/22 03:46 AM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
This
This
THIS
It helps you establish a map so you can isolate and work each circuit rather than get lost and chase your tail. You will be surprised at what else you may find that was goofed up by a prior owner as well.
Re: battery draining. Can't find the draw [Re: mopars4ever] #3075694
09/09/22 07:23 AM
09/09/22 07:23 AM
Andrewh Offline
Andrewh  Offline
https://mymopar.com/wiring/
doesn't go that new, but maybe 75 is close enough. cordoba would be similar.
Re: battery draining. Can't find the draw [Re: demon] #3075706
09/09/22 08:41 AM
09/09/22 08:41 AM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
there is a relay (3 wires) for the alternator, under passenger fender, has battery voltage at all times, unplug that
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: battery draining. Can't find the draw [Re: 440lebaron] #3075739
09/09/22 10:18 AM
09/09/22 10:18 AM
Canada
demon Offline OP
demon  Offline OP
Canada
I'll check that. Thanks for everyone's input.
The owner bought the car recently from an estate, so he doesn't know much about it. The car is very low mileage and in excellent untouched condition.
The digital clock does not function though, so I do wonder if that is possibly drawing power
Page 1 of 4 1 2 3 4
