battery draining. Can't find the draw
#3075560
09/08/22 05:03 PM
09/08/22 05:03 PM
Posts: 1,179 Canada
demon
Canada
Working on a 78 Chrysler LeBaron. It's a low mileage car, absolutely stock and untouched, other than it has had an electronic ignition conversion to eliminate the Lean burn system. So the issue is: The battery will go dead in a day or so.
Brand new battery.
With the key off, doors and trunk closed, and checked to make sure no lights are on. I pulled off the negative cable, and put a test light between the negative battery post, and the negative cable. The test light is bright. I then pulled every fuse out one by one, and no change. Test light still on. Disconnected various items such as alternator, electronic control box, wiper motor, power seat, and still no change. Anyone have an idea as to what is drawing power?
Re: battery draining. Can't find the draw
[Re: Sniper]
#3075576
09/08/22 06:24 PM
09/08/22 06:24 PM
Posts: 2,915 Calgary, Alberta Canada
a12rag
Years ago I had a similar issue. Turns out I put new trunk weatherstripping on and it held the trunk lid up enough to allow the light to remain on. Unless you get in the trunk and have someone shut it it's real hard to tell. I guess you could pull teh bulb and see if the battery drains.
I have a 64 Falcon that has trunk light with a "mercury" type switch - switch was bad and would keep light on . . . would try above for sure
[Re: demon]
#3075591
09/08/22 07:05 PM
09/08/22 07:05 PM
Posts: 5,439 So Cal
Sinitro
So Cal
Just a suggestion... Pop off each bulkhead connector, 1 by 1.... See if the light goes OFF.. This may point U in the right direction.. Just my $0.02....
[Re: 71GTX471]
#3075594
09/08/22 07:31 PM
09/08/22 07:31 PM
Posts: 15,831 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Disconnect the alt.leads & see it could be shorted. This. My '89 Diplomat fought me with this and it was the alternator.
Facts are stubborn things.
[Re: NITROUSN]
#3075626
09/08/22 09:05 PM
09/08/22 09:05 PM
Posts: 1,893 Harriman NY
71GTX471
Harriman NY
Read ....He has disconnected the alternator. My bad missed that.
[Re: demon]
#3075657
09/08/22 10:36 PM
09/08/22 10:36 PM
Posts: 15,315 Omaha Ne
TJP
Omaha Ne
I had one years ago on 63? T bird. Couldn't find it. It had the older analog clock that had points. When the clock spring needed to wound the points would close, wind the spring and the points would open. OK but this clock wasn't working so I blew by it. After chasing my tail for a few hours a buddy suggested disconnecting the clock. I said why? it's not working Well lo and behold the points were stuck shut, which overwound the spring until it broke, so the clock motor was running all the time. But you couldn't hear it and I ASSumed it was not the issue. might try the bulkheads as suggested as it might narrow it down. I would start with the wiper motor harness. It has to be something that is hot all the time and not fused by the fuse box A schematic would be very helpful as wellKeep us posted
[Re: TJP]
#3075661
09/08/22 10:43 PM
09/08/22 10:43 PM
Posts: 10,706 North Dakota
6PakBee
North Dakota
Trying to shotgun electrical problems usually never ends well. Get a wiring diagram for your car. Based on that, start removing components one by one until the problem is found. I've been through this more than once and this typically has worked best for me.
[Re: demon]
#3075667
09/08/22 11:28 PM
09/08/22 11:28 PM
Posts: 1,754 Phila
PhillyRag
Phila
Brand new battery.
With the key off, doors and trunk closed, and checked to make sure no lights are on. I pulled off the negative cable, and put a test light between the negative battery post, and the negative cable. The test light is bright. I then pulled every fuse out one by one, and no change. Test light still on. Disconnected various items such as alternator, electronic control box, wiper motor, power seat, and still no change. Anyone have an idea as to what is drawing power? Some circuits are not fused: HL,park,etc. Focus on those type circuits.
[Re: PhillyRag]
#3075685
09/09/22 02:05 AM
09/09/22 02:05 AM
Posts: 11,531 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Just have to keep disconnecting stuff until it disappears. Relays, Connections. As stated, firewall connections to try to isolate it.
[Re: 6PakBee]
#3075687
09/09/22 03:46 AM
09/09/22 03:46 AM
Posts: 2,725 541 slobovia
A990
541 slobovia
Trying to shotgun electrical problems usually never ends well. Get a wiring diagram for your car. Based on that, start removing components one by one until the problem is found. I've been through this more than once and this typically has worked best for me. This This THISIt helps you establish a map so you can isolate and work each circuit rather than get lost and chase your tail. You will be surprised at what else you may find that was goofed up by a prior owner as well.
[Re: demon]
#3075706
09/09/22 08:41 AM
09/09/22 08:41 AM
Posts: 1,605 westerly, ri. usa
440lebaron
westerly, ri. usa
there is a relay (3 wires) for the alternator, under passenger fender, has battery voltage at all times, unplug that
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: 440lebaron]
#3075739
09/09/22 10:18 AM
09/09/22 10:18 AM
Posts: 1,179 Canada
demon
Canada
there is a relay (3 wires) for the alternator, under passenger fender, has battery voltage at all times, unplug that I'll check that. Thanks for everyone's input. The owner bought the car recently from an estate, so he doesn't know much about it. The car is very low mileage and in excellent untouched condition. The digital clock does not function though, so I do wonder if that is possibly drawing power
