3-speed wiper switch resistor ?? #3070006
08/20/22 08:57 PM
08/20/22 08:57 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Anyone know the specs for the external 3-speed wiper switch resistor ??
Re: 3-speed wiper switch resistor ?? [Re: Stanton] #3074922
09/06/22 08:27 PM
09/06/22 08:27 PM
Wagoner OK
devinism Offline
devinism  Offline
Wagoner OK
25 ohm
Re: 3-speed wiper switch resistor ?? [Re: devinism] #3074930
09/06/22 08:51 PM
09/06/22 08:51 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Thanks ... I bought ten a couple weeks ago. I was the guy that messaged you through Ebay. After you replied it took some searching but I found a batch. Now I just have to figure how to attach them keeping the leads insulated. Riveting is an option but I'd prefer that as a last resort. I'm more interested in functionality than originality - nobody's going to see the switch once installed !
By the way, I'm not intending to compete with your service - its just that the things were cheap and shipping was as much for ten as it would have been for one !
Re: 3-speed wiper switch resistor ?? [Re: Stanton] #3074979
09/06/22 10:34 PM
09/06/22 10:34 PM
those are wire wound resistors, they look good up
Use a good quality ohm meter (not a cheap one tsk) and check the ohms on all of them use the one that is a close to 25.0000 ohms as possible scope twocents
Hopefully they are all dead on 25.000: wrench: luck: up
Re: 3-speed wiper switch resistor ?? [Re: Stanton] #3075038
09/07/22 08:45 AM
09/07/22 08:45 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Just cover the leads on the resistor with heat shrink
Re: 3-speed wiper switch resistor ?? [Re: Stanton] #3075384
09/08/22 01:26 AM
09/08/22 01:26 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
what does the resistor do on this switch as others dont have one ?
is this what givesit the 3 speed ?
will this turn a 2 speed into a 3 speed ?
thank you !
Re: 3-speed wiper switch resistor ?? [Re: calrobb2000] #3075414
09/08/22 09:07 AM
09/08/22 09:07 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Drops the voltage for the third speed.
yes
Not unless you can figure how to give the switch a 3rd position !!!!
The guts are different too.
