Re: 3-speed wiper switch resistor ??
[Re: Stanton]
#3074979
09/06/22 10:34 PM
09/06/22 10:34 PM
Posts: 43,285 Bend,OR USA
Cab_Burge
those are wire wound resistors, they look good Use a good quality ohm meter (not a cheap one ) and check the ohms on all of them use the one that is a close to 25.0000 ohms as possible Hopefully they are all dead on 25.000: : luck:
[Re: Stanton]
#3075038
09/07/22 08:45 AM
09/07/22 08:45 AM
Posts: 75,088 A Banana Republic near you.
JohnRR
Thanks ... I bought ten a couple weeks ago. I was the guy that messaged you through Ebay. After you replied it took some searching but I found a batch. Now I just have to figure how to attach them keeping the leads insulated. Riveting is an option but I'd prefer that as a last resort. I'm more interested in functionality than originality - nobody's going to see the switch once installed !
By the way, I'm not intending to compete with your service - its just that the things were cheap and shipping was as much for ten as it would have been for one ! Just cover the leads on the resistor with heat shrink
