15 Jeep won't start, won't crank issue
#3073320
09/01/22 03:43 PM
09/01/22 03:43 PM
Posts: 2,937 GA
roadrunninMark
GA
Hello, my friend has a 15 Jeep, I believe a Wrangler, that has a no start, no crank issue, about 85k miles. He was driving down the road and it just quit. It wouldn't even crank after this. He got it home and tried again. It started and ran for a few seconds at idle, started idling rough then quit again. Currently not even cranking. He did tried to research it online and found it to be a pretty known issue with Jeeps but no one explains in detail what is going on. There are no engine codes, just check engine light. He was thinking possibly fuel pump but thought he heard it prime up at the turn of key, not positive though. Did find out that a bad fuel pump will not throw a code. His next plan was to get a gauge on the fuel system to check if he gets any pressure. Would no fuel pressure not all keep the engine from cranking? Anyone experience this and have the know fix? Local mechanics want to charge 150 an hour just to diagnose. Who knows how long it could take it find the issue(s).
Re: 15 Jeep won't start, won't crank issue
[Re: roadrunninMark]
#3073324
09/01/22 03:52 PM
09/01/22 03:52 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
Hello, my friend has a 15 Jeep, I believe a Wrangler, that has a no start, no crank issue, about 85k miles. He was driving down the road and it just quit. It wouldn't even crank after this. He got it home and tried again. It started and ran for a few seconds at idle, started idling rough then quit again. Currently not even cranking. He did tried to research it online and found it to be a pretty known issue with Jeeps but no one explains in detail what is going on. There are no engine codes, just check engine light. He was thinking possibly fuel pump but thought he heard it prime up at the turn of key, not positive though. Did find out that a bad fuel pump will not throw a code. His next plan was to get a gauge on the fuel system to check if he gets any pressure. Would no fuel pressure not all keep the engine from cranking? Anyone experience this and have the know fix? Local mechanics want to charge 150 an hour just to diagnose. Who knows how long it could take it find the issue(s). Last May we had a fuel pump failure on the wife's '15 Hemi Durango. But it would absolutely crank over well, just no start. We had it towed to the dealer, they diagnosed it pretty quickly. I've no idea the diagnosis cost since it's under mopar warranty gold program. The receipt doesn't even list any hours.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
#3075154
09/07/22 02:24 PM
09/07/22 02:24 PM
Posts: 5,193 NEW JERSEY
AARCONV
NEW JERSEY
[align:left][/align]its not fuel, because it would crank, 1st thing to check is the battery with a multi meter and check for voltage, then at the fuse box to see if power is traveling thru the cables.and of course the grounds too. Try this https://youtu.be/72O5ALGF0Ho
[Re: MoonshineMattK]
#3076039
09/10/22 12:24 PM
09/10/22 12:24 PM
Posts: 1,177 Santa Ana, CA
DustyChicken
Santa Ana, CA
No crank no start is not indicative of a fuel problem. This is going to be electrical or electronic in nature. Start with the battery, make sure it has 12.6 volts and can pass a load test. Check the terminals, I've had just barely loose terminals cause a no-crank concern. Check the battery connection in the TIPM as well, I've seen those loose.
If all that is good then you gotta go into the modules with a good scan tool, not just a code reader. Like MoonshineMattK said, you need to check to see if the SKREEM/WCM module is seeing the key in the ignition and properly handshaking with the PCM. Any sort of mismatch between the SKREEM/WCM and the PCM will fail the security check and not allow the engine to crank.
It may also be a failed ignition switch. You'd have to use a scan tool to see if the SKREEM/WCM is seeing proper changes of state for the ignition switch as you turn the key.
If it died while driving I'd be inclined to check all the connections, battery, and verify that the alternator is working before diving into the electronics. Once the vehicle is started the security aspect of the SKREEM-PCM is no longer necessary.
[Re: DustyChicken]
#3080364
09/24/22 09:24 PM
09/24/22 09:24 PM
Posts: 15,358 Omaha Ne
TJP
Omaha Ne
If it died while driving I'd be inclined to check all the connections, battery, and verify that the alternator is working before diving into the electronics. Once the vehicle is started the security aspect of the SKREEM-PCM is no longer necessary. NAILED IT
