disc brake master cylinder that looks stock #3072626
08/30/22 02:39 PM
08/30/22 02:39 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Is there a master cylinder for manual disc brakes in size 15/16 " bore size that looks kinda stock for a late 60s or early 70s B body . with Manual disc brakes ?
OR is there even an option besides the plastic bodied version like late models
Smallest I can find is 1-1/16"
Re: disc brake master cylinder that looks stock [Re: gtx6970] #3072633
08/30/22 02:52 PM
08/30/22 02:52 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Go to the parts store and look up a 1975 Duster w/power disc brakes. It will have a 15/16" bore. Factory look.
Re: disc brake master cylinder that looks stock [Re: Cuda340] #3072649
08/30/22 03:28 PM
08/30/22 03:28 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Thanks.
Got one coming. Should be in my hand the end of today
Re: disc brake master cylinder that looks stock [Re: Cuda340] #3072729
08/30/22 06:02 PM
08/30/22 06:02 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Should look like the one in my 1973 Dart Sport. Had one that came on the car rebuilt since we knew it worked.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: disc brake master cylinder that looks stock [Re: 340SIX] #3072731
08/30/22 06:09 PM
08/30/22 06:09 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
What I found interesting.
Is they list power brakes master as 15/16 bore.
manual brakes ( same application ) has 1-1/16 bore
Re: disc brake master cylinder that looks stock [Re: gtx6970] #3072738
08/30/22 06:35 PM
08/30/22 06:35 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
That seems to be bass ackwards but it is the same on the FSM
Dorman M80266 is a good number
Re: disc brake master cylinder that looks stock [Re: Sniper] #3072758
08/30/22 08:47 PM
08/30/22 08:47 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Thanks all,
Picked it up today, should have it bled and on the car next day or 2
https://www.oreillyauto.com/detail/...duster?q=brake+master+cylinder&pos=0
Re: disc brake master cylinder that looks stock [Re: gtx6970] #3072770
08/30/22 09:26 PM
08/30/22 09:26 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I believe some of the PB cars had an additional bell crank linkage that may have changed the pedal ratio not sure which direction though shruggy
Re: disc brake master cylinder that looks stock [Re: TJP] #3072822
08/31/22 07:49 AM
08/31/22 07:49 AM
VA
dragon slayer Offline
VA
B and E did. A body had that bracket assembly, so I assume that was similar. B body power disc were 1 1/8" at least through 70
Re: disc brake master cylinder that looks stock [Re: TJP] #3072843
08/31/22 09:26 AM
08/31/22 09:26 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The 69 B bodies I owned, and my fathers 72 duster, with power discs all had this , B body under the dash , A body under the hood . I believe it was because they had to raise the assembly up so the booster would clear the engine/exhaust manifold ...
Re: disc brake master cylinder that looks stock [Re: JohnRR] #3072861
08/31/22 10:13 AM
08/31/22 10:13 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
On a side note.
My brothers 70 duster and also found some 1969 B bodies.
Manual discs were optional / available.
But yet. ......
And best i can tell.
They all had a bore size 1-1/16 or maybe 1-1/8 .
Re: disc brake master cylinder that looks stock [Re: gtx6970] #3072885
08/31/22 12:23 PM
08/31/22 12:23 PM
VA
VA
1 1/8" My understanding at least thru 70 that disc brakes mandated power disc. No manual disc early on. What happen in the 70s, I don't know. Maybe it became an option then.
Re: disc brake master cylinder that looks stock [Re: dragon slayer] #3072889
08/31/22 12:33 PM
08/31/22 12:33 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Maybe when the A body got the large bolt pattern wheels (73 up??), they gave them manual disc brakes ? I remember mom & dads 76 Valiant, bought new, had manual disc brakes.
Re: disc brake master cylinder that looks stock [Re: a12rag] #3073019
08/31/22 07:41 PM
08/31/22 07:41 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
My brother bought a 1970 Duster 340 off the original owner back in early 80s - manual disc brakes
and Since then Ive seen a few others equipped same way .
I remember reading manual disc brakes were optional on Taxis and maybe Police cars back in 68 or 69 maybe ?????
Re: disc brake master cylinder that looks stock [Re: gtx6970] #3073022
08/31/22 07:47 PM
08/31/22 07:47 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
Correct. A bodies could be had from 67-70 with manual disc brakes.
Same master cylinder for that application regardless of if it was manual or power.
And there was a manual disc brake master cylinder for 70 B body taxi. It was the same 1-1/8 bore master cylinder used on C body with disc that year with an added push rod.
Re: disc brake master cylinder that looks stock [Re: Mastershake340] #3073206
09/01/22 10:44 AM
09/01/22 10:44 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I think I have one of these NOS I bought about 8 years ago ...
Re: disc brake master cylinder that looks stock [Re: gtx6970] #3074285
09/04/22 07:26 PM
09/04/22 07:26 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Fixed it.
Bench bled and on the car.
A quick bleed all around. Then took it for a spin.
I feel much better now if my daughter drives it.
Car stops really well.
