Re: disc brake master cylinder that looks stock
[Re: Cuda340]
#3072729
08/30/22 06:02 PM
08/30/22 06:02 PM
Posts: 28,596 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
Go to the parts store and look up a 1975 Duster w/power disc brakes. It will have a 15/16" bore. Factory look. Should look like the one in my 1973 Dart Sport. Had one that came on the car rebuilt since we knew it worked.
[Re: gtx6970]
#3072738
08/30/22 06:35 PM
08/30/22 06:35 PM
Posts: 6,246 nowhere
Sniper
nowhere
What I found interesting. Is they list power brakes master as 15/16 bore. manual brakes ( same application ) has 1-1/16 bore That seems to be bass ackwards but it is the same on the FSM Dorman M80266 is a good number
[Re: TJP]
#3072843
08/31/22 09:26 AM
08/31/22 09:26 AM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
What I found interesting. Is they list power brakes master as 15/16 bore. manual brakes ( same application ) has 1-1/16 bore I believe some of the PB cars had an additional bell crank linkage that may have changed the pedal ratio not sure which direction though The 69 B bodies I owned, and my fathers 72 duster, with power discs all had this , B body under the dash , A body under the hood . I believe it was because they had to raise the assembly up so the booster would clear the engine/exhaust manifold ...
[Re: Mastershake340]
#3073206
09/01/22 10:44 AM
09/01/22 10:44 AM
JohnRR
U.S.S.A.
And there was a manual disc brake master cylinder for 70 B body taxi. It was the same 1-1/8 bore master cylinder used on C body with disc that year with an added push rod.
I think I have one of these NOS I bought about 8 years ago ...
