Tie Down #3070796
08/23/22 02:17 PM
08/23/22 02:17 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
Guys with ladder bar/4 link cars how are you attaching the tie down straps on the rear of your car? Pics would be great. Thanks.
Re: Tie Down [Re: DusterKid] #3070808
08/23/22 02:55 PM
08/23/22 02:55 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I have tie down loops welded to my frame rails, front and rear on my car. You can see them here just after the wheel tubs. I prefer to tie the car down like this so the suspension isn't moving, and shocks wearing out.
69 GTX 68 Road Runner
Re: Tie Down [Re: JERICOGTX] #3070858
08/23/22 05:37 PM
08/23/22 05:37 PM
Georgia and Washington
JMCarter Offline
JMCarter  Offline
Center of the back bracing for the nine inch housing has loops welded into it. Cross the tie downs.
Re: Tie Down [Re: DusterKid] #3070863
08/23/22 06:21 PM
08/23/22 06:21 PM
AndyF Offline
AndyF  Offline
Re: Tie Down [Re: AndyF] #3070927
08/23/22 10:29 PM
08/23/22 10:29 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
My Valiant has frame loops like Jeff's Roadrunner on back. Front I just put straps over the strut rods and hook the ratchet straps to them.
Re: Tie Down [Re: slantzilla] #3070958
08/24/22 01:08 AM
08/24/22 01:08 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
S60 with ladder bar and wheelie bar brackets….. have to cross the rear straps to clear the wheelie bar mounts which I’m NOT a fan of. Tire goes down the car will get pulled to that side. I need to add some more D rings in the floor to remedy this.
Re: Tie Down [Re: DusterKid] #3070965
08/24/22 03:19 AM
08/24/22 03:19 AM
I use two 5,000 Lb, rated straps with D rings on each end over the rear end axle tubes held by two 5000 Lb. rated ratchet strap hold downs on the rear end hook to two d rings in the floor and two of the same straps and hold downs looped around the K member in the front hook to the front D rings by the front ratchet tie downsup wrench
Works good, last a long time.
If I'm towing more than 50 miles, I will stop once and retighten the rears up They will stretch a little and get a tiny bit loose shruggy
Re: Tie Down [Re: Cab_Burge] #3071011
08/24/22 09:30 AM
08/24/22 09:30 AM
Mo.
racerx Offline
racerx  Offline
Mo.
And hate when they do that mad
Re: Tie Down [Re: racerx] #3071078
08/24/22 01:22 PM
08/24/22 01:22 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mine has a long bolt in the lower rear ladder bar mount. A loop is attached over that bolt with with an additional nut.
Doug
Re: Tie Down [Re: JERICOGTX] #3071087
08/24/22 01:57 PM
08/24/22 01:57 PM
NC
440Jim Offline
440Jim  Offline
NC
Like Jeff says, attaching to the frame pulls the car suspension down, so it doesn't bounce around as much (which can wear shocks).
When I bought my Daytona, the previous owner had frame loops on the front, but axle loops on the rear. He showed me how he used an extra strap on the parachute frame to pull the suspension down. Saving the shocks.
