Re: Tie Down
[Re: DusterKid]
#3070808
08/23/22 02:55 PM
08/23/22 02:55 PM
Posts: 10,049 MN
JERICOGTX
MN
I have tie down loops welded to my frame rails, front and rear on my car. You can see them here just after the wheel tubs. I prefer to tie the car down like this so the suspension isn't moving, and shocks wearing out.
69 GTX
68 Road Runner
Re: Tie Down
[Re: AndyF]
#3070927
08/23/22 10:29 PM
08/23/22 10:29 PM
Posts: 20,226 Park Forest, IL
slantzilla
Park Forest, IL
My Valiant has frame loops like Jeff's Roadrunner on back. Front I just put straps over the strut rods and hook the ratchet straps to them.
Re: Tie Down
[Re: DusterKid]
#3070965
08/24/22 03:19 AM
08/24/22 03:19 AM
Posts: 43,352 Bend,OR USA
Cab_Burge
I use two 5,000 Lb, rated straps with D rings on each end over the rear end axle tubes held by two 5000 Lb. rated ratchet strap hold downs on the rear end hook to two d rings in the floor and two of the same straps and hold downs looped around the K member in the front hook to the front D rings by the front ratchet tie downs Works good, last a long time. If I'm towing more than 50 miles, I will stop once and retighten the rears They will stretch a little and get a tiny bit loose
Re: Tie Down
[Re: JERICOGTX]
#3071087
08/24/22 01:57 PM
08/24/22 01:57 PM
Posts: 16,934 NC
440Jim
NC
I have tie down loops welded to my frame rails, front and rear on my car. You can see them here just after the wheel tubs. I prefer to tie the car down like this so the suspension isn't moving, and shocks wearing out. Like Jeff says, attaching to the frame pulls the car suspension down, so it doesn't bounce around as much (which can wear shocks). When I bought my Daytona, the previous owner had frame loops on the front, but axle loops on the rear. He showed me how he used an extra strap on the parachute frame to pull the suspension down. Saving the shocks.
