318 to 360 #3070126
08/21/22 11:40 AM
08/21/22 11:40 AM
fredericksburg,va
cudaman1969 Online sleepy OP
cudaman1969  Online Sleepy OP
fredericksburg,va
I have a 88 pickup with the 318 TBI, very little oil pressure (light stays on or flickers). I have a 92 360 TBI engine in better shape. Can I use the 360 with the 318 engine controller? I have the 92 control box (look very similar) but it’s in a van and I'm thinking it would be a hassle to change wiring from van to truck. I have the FSM for the 88 truck but not the van. Also if I change engines I want to do the overdrive trans that’s hooked to the 360. Any suggestions
Re: 318 to 360 [Re: cudaman1969] #3070169
08/21/22 02:09 PM
08/21/22 02:09 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
just for piece of mind I'd throw a manual oil gauge on it first.
1981 Dodge D150 360 auto
Re: 318 to 360 [Re: cudaman1969] #3070304
08/21/22 09:47 PM
08/21/22 09:47 PM
Guitar Jones Offline
The 318 PCM won't cut it. The van PCM should work if it has the same 60 way connector.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 318 to 360 [Re: Guitar Jones] #3070342
08/22/22 12:12 AM
08/22/22 12:12 AM
fredericksburg,va
fredericksburg,va
I’ll compare the two connectors
Re: 318 to 360 [Re: cudaman1969] #3070502
08/22/22 03:59 PM
08/22/22 03:59 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
2 pics from fsm 1st is 88 5.2 and 2nd is 92 5.9. looks like the sob's are sideways. sorry.
Re: 318 to 360 [Re: trw1982] #3070579
08/22/22 07:52 PM
08/22/22 07:52 PM
fredericksburg,va
fredericksburg,va
Thanks I’ll look it over tonite
Re: 318 to 360 [Re: cudaman1969] #3070718
08/23/22 10:50 AM
08/23/22 10:50 AM
Maine
jerseybud Offline
jerseybud  Offline
Maine
88 ecm has the 14 and 60 pin connector, 92 ecu has the 60 pin only connector.
Van harness would need some major extension and wire work to fit truck.
Re: 318 to 360 [Re: jerseybud] #3070825
08/23/22 03:43 PM
08/23/22 03:43 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
jerseybud, you may be correct in thinking wires might need to be longer but think about this. i think the van pcm sits right under hood and the motor sits farther back. might not be too many wires that need attention. i would be doing that swap and moving the van pcm to the blower motor area like 94 up. heck with putting pcm under drivers fender by battery. wires may have to be shortened then but could tie them up out of way. i wouldn't let that stop me from doing the swap.
Re: 318 to 360 [Re: trw1982] #3071113
08/24/22 03:50 PM
08/24/22 03:50 PM
fredericksburg,va
fredericksburg,va
Thanks for the thoughts guys. 3 heads are better than one
Re: 318 to 360 [Re: cudaman1969] #3072106
08/28/22 04:06 PM
08/28/22 04:06 PM
fredericksburg,va
fredericksburg,va
Looking at the firewall block it’s different also, same amount of pins. Then steering column then dash. I’m thinking just put the 360 in and use the 318 stuff then work trans with pressure switches, there’s a kit made for that
