Holley Sniper question #3070170
08/21/22 02:11 PM
08/21/22 02:11 PM
Rittman Ohio
fourgearsavoy Online tonguue OP
fourgearsavoy  Online Tonguue OP
Rittman Ohio
I will be installing a Holley Sniper EFI on a buddies car and he has a dual plane intake. Will I need to remove or trim the plenum divider down? I have the manifold off right now while I'm building the engine so now is the time if need to modify the intake.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Holley Sniper question [Re: fourgearsavoy] #3070185
08/21/22 03:00 PM
08/21/22 03:00 PM
I've been told by several very good EFI reps to never use a dual plane intake under any throttle body EFI systems shruggy work
All the direct port EFI systems I have seen are single plane designs also: work:
Re: Holley Sniper question [Re: fourgearsavoy] #3070235
08/21/22 06:28 PM
08/21/22 06:28 PM
AndyF Offline
AndyF  Offline
Gus beer
You don't need to do anything to the intake to run a Sniper. The Sniper will work just like a carb with fuel being introduced into all four barrels. So if a carb works on that intake then so will a Sniper. Your buddy might notice a part throttle whistle from the Sniper. If there is room you could put a thin four hole spacer under the Sniper to eliminate the whistle.
Here is the setup I used on my Coronet for a few years. This was a low deck 512 with a Performer RPM intake. It made excellent power on the dyno and ran really hard on the street.
Re: Holley Sniper question [Re: AndyF] #3070250
08/21/22 07:24 PM
08/21/22 07:24 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I recomend thinning down the divider on a DP as mush as possible and running an open spacer below the TB...Work really well on my FAST system.
Mine loved the change...
Re: Holley Sniper question [Re: Dragula] #3070257
08/21/22 08:04 PM
08/21/22 08:04 PM
Rittman Ohio
Rittman Ohio
Thanks a bunch guys up I have a few spacers on the shelf that would work.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Holley Sniper question [Re: fourgearsavoy] #3070271
08/21/22 08:33 PM
08/21/22 08:33 PM
AndyF Offline
AndyF  Offline
If you have room you can play with spacers. An open spacer on a dual plane intake will add some top end power, but with a Sniper you'll hear a whistle sound.
Re: Holley Sniper question [Re: AndyF] #3070323
08/21/22 10:38 PM
08/21/22 10:38 PM
Rittman Ohio
Rittman Ohio
The engine is a 408 Magnum with a mild hydraulic roller going into a 73 Satellite/Roadrunner clone with the bubble hood so clearance shouldn't be a problem.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Holley Sniper question [Re: fourgearsavoy] #3070358
08/22/22 08:08 AM
08/22/22 08:08 AM
Dragula Offline
Dragula  Offline
Gus beer
Mine was a 360 with a hydraulic 484 cam, and it loved the open plenum change with the spacer...It seemed more responsive and just wanted to run....
Re: Holley Sniper question [Re: Dragula] #3070369
08/22/22 09:09 AM
08/22/22 09:09 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I know engine masters did an episode carb vs EFI and the EFI hated the dual plane intake. All engines are different though.
Episode
https://www.dailymotion.com/video/x3moa13
68 Barracuda Formula S 340
Re: Holley Sniper question [Re: Bad340fish] #3070393
08/22/22 10:18 AM
08/22/22 10:18 AM
AndyF Offline
AndyF  Offline
Here is a Holley Sniper on a Performer RPM dual plane intake. It pulls hard all the way to 160 mph wheel speed. I can guarantee that there is zero problems with a Sniper on a good dual plane intake manifold. We've tested dozens of them over the years, they work just fine.
https://youtu.be/xG3-_YJGdZ8
Re: Holley Sniper question [Re: fourgearsavoy] #3070969
08/24/22 05:13 AM
08/24/22 05:13 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
If you have the hood clearance, I would use a open phenolic carb spacer.
I think the open spacer would allow the MAP sensor to sense average pressure of both planes?
The phenolic will get the EFI unit further from the intake manifold heat. The Sniper / Fitech units have the electronics inside the throttle bodies, and electronics don't like high temperatures.
