Holley Sniper question
#3070170
08/21/22 02:11 PM
08/21/22 02:11 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
I will be installing a Holley Sniper EFI on a buddies car and he has a dual plane intake. Will I need to remove or trim the plenum divider down? I have the manifold off right now while I'm building the engine so now is the time if need to modify the intake. Thanks Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Holley Sniper question
[Re: fourgearsavoy]
#3070235
08/21/22 06:28 PM
08/21/22 06:28 PM
Posts: 31,024 Oregon
AndyF
I will be installing a Holley Sniper EFI on a buddies car and he has a dual plane intake. Will I need to remove or trim the plenum divider down? I have the manifold off right now while I'm building the engine so now is the time if need to modify the intake. Thanks Gus You don't need to do anything to the intake to run a Sniper. The Sniper will work just like a carb with fuel being introduced into all four barrels. So if a carb works on that intake then so will a Sniper. Your buddy might notice a part throttle whistle from the Sniper. If there is room you could put a thin four hole spacer under the Sniper to eliminate the whistle. Here is the setup I used on my Coronet for a few years. This was a low deck 512 with a Performer RPM intake. It made excellent power on the dyno and ran really hard on the street.
[Re: AndyF]
#3070250
08/21/22 07:24 PM
08/21/22 07:24 PM
Posts: 12,387 Taxes & Virus's R-US, NY
Dragula
I recomend thinning down the divider on a DP as mush as possible and running an open spacer below the TB...Work really well on my FAST system.
Mine loved the change...
[Re: Dragula]
#3070257
08/21/22 08:04 PM
08/21/22 08:04 PM
fourgearsavoy
Rittman Ohio
Thanks a bunch guys I have a few spacers on the shelf that would work. Gus
[Re: AndyF]
#3070323
08/21/22 10:38 PM
08/21/22 10:38 PM
fourgearsavoy
Rittman Ohio
The engine is a 408 Magnum with a mild hydraulic roller going into a 73 Satellite/Roadrunner clone with the bubble hood so clearance shouldn't be a problem. Gus
[Re: fourgearsavoy]
#3070358
08/22/22 08:08 AM
08/22/22 08:08 AM
Dragula
The engine is a 408 Magnum with a mild hydraulic roller going into a 73 Satellite/Roadrunner clone with the bubble hood so clearance shouldn't be a problem. Gus Mine was a 360 with a hydraulic 484 cam, and it loved the open plenum change with the spacer...It seemed more responsive and just wanted to run....
