et gain #3067271
08/12/22 09:27 AM
08/12/22 09:27 AM
westerly, ri. usa
440lebaron Offline OP
westerly, ri. usa
2 runs stocker, high mileage 383 large amount blow-by
14.14 14.15
94 mph
change oil added 1 qt Lucas oil stabilizer, state's better ring seal less blow-by
next race about same weather
13.67 13.63
98 mph
who knows???????
running Epping 25th, changing to E-3 plugs
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: et gain [Re: 440lebaron] #3067289
08/12/22 10:20 AM
08/12/22 10:20 AM
moparx Offline
moparx  Offline
what vehicle was this ?
beer
Re: et gain [Re: moparx] #3067291
08/12/22 10:28 AM
08/12/22 10:28 AM
westerly, ri. usa
westerly, ri. usa
1975 chrysler cordoba set up for nhra L/SA 4300 lbs
Re: et gain [Re: 440lebaron] #3067339
08/12/22 12:57 PM
08/12/22 12:57 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
What was the weather swing between both days?
Doug
Re: et gain [Re: 440lebaron] #3067340
08/12/22 12:58 PM
08/12/22 12:58 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
I guarantee you the DA at Numidia was way higher than the DA at Atco...there's your ET gain...
Re: et gain [Re: sixpakdodge] #3067365
08/12/22 02:31 PM
08/12/22 02:31 PM
westerly, ri. usa
westerly, ri. usa
DA numida 2448 da atco 2640
Re: et gain [Re: 440lebaron] #3067382
08/12/22 03:34 PM
08/12/22 03:34 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Looks like....... with a couple more oil changes like that...... it’ll be running under the index grin
Re: et gain [Re: fast68plymouth] #3067395
08/12/22 04:45 PM
08/12/22 04:45 PM
westerly, ri. usa
westerly, ri. usa
There was a lot of carbon on the valves 1/4 blast probley cleaned them off
Re: et gain [Re: 440lebaron] #3067458
08/12/22 08:16 PM
08/12/22 08:16 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
2 big ones from Numedia to Atco, at least.
Re: et gain [Re: 440lebaron] #3067541
08/13/22 08:46 AM
08/13/22 08:46 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
That could very well be. Just to do it I have flowed heads as they came off the car with carbon on the valves, and then flowed after cleaning carbon. Big difference in flow, especially the carbon on the backside of the valves which usually will not burn off under hard runs. I would try some good carbon cleaning chemicals, like BG products or GM top engine cleaner.
Re: et gain [Re: jwb123] #3067588
08/13/22 11:27 AM
08/13/22 11:27 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Do you have a weather station ?
DA is just one part of it
Water grains are very important also
....BAD A$$ STREET CAR.....
Re: et gain [Re: n20mstr] #3067681
08/13/22 04:25 PM
08/13/22 04:25 PM
So. Burlington, Vt.
So. Burlington, Vt.
Someone I know had a SS car at both races...... was over a tenth quicker at the Atco race.
