et gain
#3067271
08/12/22 09:27 AM
08/12/22 09:27 AM
Posts: 1,602 westerly, ri. usa
440lebaron
westerly, ri. usa
2 runs stocker, high mileage 383 large amount blow-by 14.14 14.15 94 mph change oil added 1 qt Lucas oil stabilizer, state's better ring seal less blow-by next race about same weather 13.67 13.63 98 mph who knows??????? running Epping 25th, changing to E-3 plugs
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
Re: et gain
[Re: moparx]
#3067291
08/12/22 10:28 AM
08/12/22 10:28 AM
440lebaron
westerly, ri. usa
1975 chrysler cordoba set up for nhra L/SA 4300 lbs
Re: et gain
[Re: sixpakdodge]
#3067365
08/12/22 02:31 PM
08/12/22 02:31 PM
440lebaron
westerly, ri. usa
DA numida 2448 da atco 2640
Re: et gain
[Re: fast68plymouth]
#3067395
08/12/22 04:45 PM
08/12/22 04:45 PM
440lebaron
westerly, ri. usa
There was a lot of carbon on the valves 1/4 blast probley cleaned them off
Re: et gain
[Re: 440lebaron]
#3067541
08/13/22 08:46 AM
08/13/22 08:46 AM
Posts: 873 Missouri
jwb123
Missouri
There was a lot of carbon on the valves 1/4 blast probley cleaned them off That could very well be. Just to do it I have flowed heads as they came off the car with carbon on the valves, and then flowed after cleaning carbon. Big difference in flow, especially the carbon on the backside of the valves which usually will not burn off under hard runs. I would try some good carbon cleaning chemicals, like BG products or GM top engine cleaner.
Re: et gain
[Re: n20mstr]
#3067681
08/13/22 04:25 PM
08/13/22 04:25 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Someone I know had a SS car at both races...... was over a tenth quicker at the Atco race.
