60 ft. #3066272
08/08/22 03:56 PM
08/08/22 03:56 PM
westerly, ri. usa
440lebaron Offline OP
westerly, ri. usa
hi, ran my stocker cordoba at atco this past weekend with junkyard motor in SST, whats a good sixty ft? i was .190 best 4365 lbs. 13.64 98 mph
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: 60 ft. [Re: 440lebaron] #3066281
08/08/22 04:11 PM
08/08/22 04:11 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Wallace says @ 98MPH, 1.88 60", 13.52 1/4. So you aren't too far off. Closer than a lot of folks.
MPH gives you an idea of horsepower to weight, as long as your gearing is not out of whack. Then you can fill in the blanks of what the potential is.
Plenty of places in a Stocker to free up parasitic losses and make the most of available HP. It's all about the budget.
Re: 60 ft. [Re: CMcAllister] #3066307
08/08/22 06:13 PM
08/08/22 06:13 PM
Red Deer, Alberta
Greenwood Offline
Greenwood  Offline
Red Deer, Alberta
Play with launch rpm, i.e how much you are pre-loading the converter. Front tire pressure and front end travel. If you are running a TQ, they respond well to changes in the air door opening rate, which can have a noticeable effect on your 60'. My old 340, for example, liked the air door slowed up just a bit. This made the transition to WOT just a little smoother, and actually shortened the 60' time. Run as much air in the back tires as you can and still hook.
Re: 60 ft. [Re: Greenwood] #3066355
08/08/22 08:30 PM
08/08/22 08:30 PM
westerly, ri. usa
westerly, ri. usa
running t/q launching with 2 step , i can hold car on line at 3000 rpm, carb set up by nat record holder,
Re: 60 ft. [Re: 440lebaron] #3066427
08/09/22 01:02 AM
08/09/22 01:02 AM
Red Deer, Alberta
Greenwood Offline
Greenwood  Offline
Red Deer, Alberta
That'll work! ^^^ How much converter and gear?
Re: 60 ft. [Re: Greenwood] #3066475
08/09/22 09:41 AM
08/09/22 09:41 AM
westerly, ri. usa
westerly, ri. usa
4:56 maybe 4500-5500 stall, haven't checked yet T/A 8" converter made for car
Re: 60 ft. [Re: 440lebaron] #3066518
08/09/22 12:21 PM
08/09/22 12:21 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
I see you asking questions other places, the right places. Good for you.
Maybe I've missed it. What gear is in the car? 2.45 low? What does it RPM in the lights currently?
I would be careful spending a bunch of money, on parts that won't be usable, sorting and improving the current combination, until you get enough power in the car to make it run a decent number for whatever class you are shooting for. Doesn't have to be legal. Just has to make similar steam. Then your work will be relevant.
NVM, I see 4.56. 100MPH on a 30" tire with that gear looks like 5400-5500 in the lights, depending on the converter. Right?
Re: 60 ft. [Re: CMcAllister] #3066572
08/09/22 02:45 PM
08/09/22 02:45 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
You’re getting your grade points....... that’s good.
Mission accomplished.
Frankly, I wouldn’t change anything until the correct legal engine is in the car.
Re: 60 ft. [Re: 440lebaron] #3066585
08/09/22 03:01 PM
08/09/22 03:01 PM
The good stockers cars in your class probably 60 foot in the low 1.40 to high 3.80 scope
My message is to focus on the first 60 Ft. and let the rest of the track take care of itself twocents
The converter, chassis and suspension and fuel system will be where you can make your most and best gains wrench scope
The car needs to be perfect and better than all the other cars out there from the front bumper bolts to the rear bumper bolts to set the records and win class up scope Piece of cake, right: whistling:
Good luck on this venture: up:
Re: 60 ft. [Re: fast68plymouth] #3066612
08/09/22 04:45 PM
08/09/22 04:45 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
This. Doesn't need to be a record setter. But it needs to get under the index, the further the better.
Re: 60 ft. [Re: CMcAllister] #3066666
08/09/22 08:47 PM
08/09/22 08:47 PM
westerly, ri. usa
westerly, ri. usa
5600 finish line 30" tire, will not be spending money on this motor , just shaking down car and getting grade points, very laid back having fun dont care if we miss a time trial go home when the call 1st round or stay and watch the show
Re: 60 ft. [Re: 440lebaron] #3066765
08/10/22 09:55 AM
08/10/22 09:55 AM
Georgia and Washington
JMCarter Offline
JMCarter  Offline
Kudos for running in Super Street to get the grade point. Have seen people try to pass an illegal motor off and run in their respective stock class and that doesn’t end well. Rooting for you!
Re: 60 ft. [Re: 440lebaron] #3066772
08/10/22 10:15 AM
08/10/22 10:15 AM
So. Burlington, Vt.
So. Burlington, Vt.
Quote
Looks like about 12% slip........ which seems about right for an 8” converter, 4300lbs, running in that rpm range(it would slip less if the car were geared for the engine to run 6500-7000).
Re: 60 ft. [Re: 440lebaron] #3066799
08/10/22 12:51 PM
08/10/22 12:51 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
I agree on the grade points if you want to run the big show. IIRC, Super Street grade points only allowed you to run national events in Super Street where it was included in the lineup. That may have changed. May want to check on that. Too many guys were getting grade points with their bracket car and showing up with the Super Stocker. Points races are a mighty expensive TnT.
Re: 60 ft. [Re: CMcAllister] #3066865
08/10/22 04:53 PM
08/10/22 04:53 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
You need to have S/ST grade points to run S/ST at a National, but can use your S/ST grade points to run other classes at a National. Many D1 S/ST racers run in Super Gas at the National Events.
Re: 60 ft. [Re: sixpakdodge] #3067026
08/11/22 10:51 AM
08/11/22 10:51 AM
westerly, ri. usa
westerly, ri. usa
MY goal is to run Indy next year in STK with new motor, should have motor this fall and TNT at atco, there open till dec. need at least 5 grade points and .4 under index (12.70)
Re: 60 ft. [Re: 440lebaron] #3067041
08/11/22 11:39 AM
08/11/22 11:39 AM
Are you saying you need to be able to run .4 under the index to get into, qualify for that race or you want to run .4 under to qualify better?
You will need to be able to outrun any other car in your class to be able to get to the next round whistling grin
Good luck, be patient up
Re: 60 ft. [Re: Cab_Burge] #3067053
08/11/22 12:11 PM
08/11/22 12:11 PM
So. Burlington, Vt.
So. Burlington, Vt.
Since Stock filled up so quick this year, I’m expecting the amount one has to run under the index will be back to what it was prior to the pandemic.
The cut off point for qualifying in Stock the last two years at the US Nationals has been well below(slower) what was typical in the past..........when many cars running .8xx under the index didn’t get in.
In 2019 you had to go .867 under or quicker to get in........ which was more typical for that event.
The last couple of years it’s been in the .400 under range.
Re: 60 ft. [Re: fast68plymouth] #3067068
08/11/22 01:11 PM
08/11/22 01:11 PM
westerly, ri. usa
westerly, ri. usa
I'm expecting to run 12.20-12.30 480 hp i know I'm going to be in trouble if I get a heads-up round, there running 11.90 12.00 ($3000 valve job) if I can't go .4-.6 under we will go to Bristol or charlotte, 14 hour ride for 2 time trials frown we are based in the northeast, this is somewhat of a bucket list
Re: 60 ft. [Re: 440lebaron] #3067098
08/11/22 03:08 PM
08/11/22 03:08 PM
So. Burlington, Vt.
So. Burlington, Vt.
Most national events don’t have the maximum sized field of cars(128), so they end up being “all run”, with qualifying just setting up the pairings/ladder.
But Indy basically always has more than 128 people show up........ so, if you’re not quick enough to be one of the top 128....... you’re a spectator.
