Re: Ranco heater valve rebuild ?
[Re: 469runner]
#3066859
08/10/22 04:30 PM
08/10/22 04:30 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
I did mine myself, DMT has a rebuild kit
[Re: autoxcuda]
#3066996
08/11/22 07:45 AM
08/11/22 07:45 AM
Posts: 10,766 North Dakota
6PakBee
North Dakota
This is how the AMC guys do it. RANCO valve rebuild
[Re: 6PakBee]
#3067213
08/11/22 11:57 PM
08/11/22 11:57 PM
Posts: 27,483 So Cal
autoxcuda
So Cal
Need to be a member to access that page ;( Do you have a screenshot from there of what the basic Ranco looks like?
[Re: autoxcuda]
#3067302
08/12/22 10:51 AM
08/12/22 10:51 AM
6PakBee
North Dakota
Need to be a member to access that page ;( Do you have a screenshot from there of what the basic Ranco looks like? Didn't realize that. It sucks. But moving ahead, here is one AMC version of the Ranco valve. And as you surmised, they are pretty much the same other than the brackets. So that is for the most part what a "rebuild" consists of, moving the brackets.
[Re: 6PakBee]
#3067589
08/13/22 11:29 AM
08/13/22 11:29 AM
autoxcuda
So Cal
Need to be a member to access that page ;( Do you have a screenshot from there of what the basic Ranco looks like? Didn't realize that. It sucks. But moving ahead, here is one AMC version of the Ranco valve. And as you surmised, they are pretty much the same other than the brackets. So that is for the most part what a "rebuild" consists of, moving the brackets. Are the rubber parts the DMT sells are for if you take your original valve unit apart? I found that new four seasons 74661 unit in gold cad. Looks like the stock unit. Anytime you have two different places or even batches of gold cad done, often time they don't match 100%. Because these parts are connected, any differences will stand out more. That's if it matters to you. Point is, I can see the value of rebuilding your old one with the DMT parts. ![[Linked Image]](https://i.ebayimg.com/images/g/f1kAAOSwE1hiDBYm/s-l1600.jpg)
[Re: autoxcuda]
#3067650
08/13/22 02:31 PM
08/13/22 02:31 PM
CSK
Pattison Texas
The Ranco valve I am talking about is like this
[Re: CSK]
#3068025
08/14/22 10:44 PM
08/14/22 10:44 PM
6PakBee
North Dakota
The Ranco valve I am talking about is like this Completely different animal. Completely.
