Big Block water hose fittings #3066150
08/08/22 12:41 AM
08/08/22 12:41 AM
Washington
hemienvy Online content OP
hemienvy  Online Content OP
Washington
The two fittings on the water pump housing, anybody make those in stainless ?
Re: Big Block water hose fittings [Re: hemienvy] #3066157
08/08/22 07:45 AM
08/08/22 07:45 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Classic Industries carries some on their website. Not factory appearing if you care about that sort of thing.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Big Block water hose fittings [Re: hemienvy] #3066193
08/08/22 11:05 AM
08/08/22 11:05 AM
AndyF Online content
AndyF  Online Content
Hoffman Winners Circle probably has the best fittings.
Re: Big Block water hose fittings [Re: hemienvy] #3066196
08/08/22 11:11 AM
08/08/22 11:11 AM
MarkZ Online boogie
Worthy
MarkZ  Online Boogie
Worthy
Wouldn't that create a problem with an aluminum pump housing (assuming it's not iron)?
Re: Big Block water hose fittings [Re: MarkZ] #3066204
08/08/22 11:34 AM
08/08/22 11:34 AM
moparx Offline
moparx  Offline
what kind of a problem ?
a good coating of Loctite 567, which is my favorite sealant, will seal the fittings and prevent any galvanic corrosion if you are worried about that.
beer
Re: Big Block water hose fittings [Re: moparx] #3066274
08/08/22 03:57 PM
08/08/22 03:57 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Do they make them in aluminum? I put s sealant on mine like was said. Was fine for years. Not sure how long it’d take to see a corrosion issue.
I want my fair share
Re: Big Block water hose fittings [Re: SomeCarGuy] #3066310
08/08/22 06:21 PM
08/08/22 06:21 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I think aluminum would be too soft.
Agree on using thread sealant.
Haven't needed any heater hose fittings for a long time, but they're available from vendors.
But if you use brass, it's invisible when the hoses are on.
Re: Big Block water hose fittings [Re: topside] #3066336
08/08/22 07:59 PM
08/08/22 07:59 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Nice thing about brass, it doesn't 'grow attached' to either steel or aluminum. Miracle metal. twocents
Re: Big Block water hose fittings [Re: John Brown] #3066459
08/09/22 08:31 AM
08/09/22 08:31 AM
VA
dragon slayer Offline
VA
Loctite doesn't state it can prevent corrosion, just a low strength sealant for course and taper thread fittings.
Re: Big Block water hose fittings [Re: dragon slayer] #3066484
08/09/22 10:29 AM
08/09/22 10:29 AM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
I use solid brass ones from Grainger on
They're listed as "Beaded Hose Fitting"
I especially like that they can be insalled & removed with a deep socket.
just make sure you get the correct NPT size
https://www.grainger.com/product/GR...?findingMethod=orderHistory&opr=ODOH
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
