Re: Big Block water hose fittings
[Re: hemienvy]
#3066157
08/08/22 07:45 AM
08/08/22 07:45 AM
Posts: 3,380 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
The two fittings on the water pump housing, anybody make those in stainless ? Classic Industries carries some on their website. Not factory appearing if you care about that sort of thing.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: hemienvy]
#3066196
08/08/22 11:11 AM
08/08/22 11:11 AM
Posts: 4,421 Michigan
MarkZ
Worthy
Worthy
Wouldn't that create a problem with an aluminum pump housing (assuming it's not iron)?
[Re: moparx]
#3066274
08/08/22 03:57 PM
08/08/22 03:57 PM
Posts: 10,214 Someplace you aren't
SomeCarGuy
Do they make them in aluminum? I put s sealant on mine like was said. Was fine for years. Not sure how long it’d take to see a corrosion issue.
I want my fair share
[Re: dragon slayer]
#3066484
08/09/22 10:29 AM
08/09/22 10:29 AM
Posts: 5,784 Corpus Christi, TX
shanker
Corpus Christi, TX
I use solid brass ones from Grainger on They're listed as "Beaded Hose Fitting" I especially like that they can be insalled & removed with a deep socket. just make sure you get the correct NPT size https://www.grainger.com/product/GR...?findingMethod=orderHistory&opr=ODOH
The Federal Government has not yet learned that you cannot legislate morality
1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23
1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55
1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91
1975 Duster 360 VS29L5 Daily Driver
