Re: TC bolt tightening sequence [Re: cudaman1969] #3066110
08/07/22 06:54 PM
08/07/22 06:54 PM
BDW Offline OP
BDW  Offline OP
Well that was a F'in nightmare,
Flex plate is a universal deal that fits 3 different configurations, took me forever to find the right orientation......
Crawling under car, try, crawl back out, turn motor using socket..........rinse and repeat.
And there was not enough room to use a torque wrench, so calibrated crank and loctite will have to do.
Thx for all the replies, but unless there's a low profile 1/4" torque wrench / socket combo, its not happening.....
Re: TC bolt tightening sequence [Re: BDW] #3066115
08/07/22 07:16 PM
08/07/22 07:16 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Now spray paint the converter and flex plate by one of the bolts so it’s easy to line up next time. I do this on the floor before installation.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: TC bolt tightening sequence [Re: John_Kunkel] #3066182
08/08/22 10:22 AM
08/08/22 10:22 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted by John_Kunkel
And red Loctite.
I use blue on Cummins convertors and never heard of them loosening.
Re: TC bolt tightening sequence [Re: cudaman1969] #3066183
08/08/22 10:26 AM
08/08/22 10:26 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted by cudaman1969
Since the 90s all the converter bolts (at least the ones for dodge trucks) come with loctite on them and to not reuse the old ones.
I spent a couple year hopping up transmissions for 2nd Gen Dodges with Cummins and V10's about 2002/3 , always reused the bolts with blue loctite , no issues I ever heard of ...
YMMV
Re: TC bolt tightening sequence [Re: JohnRR] #3066189
08/08/22 10:52 AM
08/08/22 10:52 AM
PA.
"Little"John
"Little"John
PA.
Blue, red it doesn’t matter and isn’t worth arguing over. Just remember to clean any oil from the bolts and converter threads.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: TC bolt tightening sequence [Re: pittsburghracer] #3066202
08/08/22 11:30 AM
08/08/22 11:30 AM
moparx Online content
moparx  Online Content
"Now spray paint the converter and flex plate by one of the bolts so it’s easy to line up next time. I do this on the floor before installation."
iagree i do this before i separate the transmission if i'm going to use the same combo, and it hasn't been marked like this previously.
makes life SO much easier !
beer
Re: TC bolt tightening sequence [Re: BDW] #3066208
08/08/22 11:46 AM
08/08/22 11:46 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Torqueflite? I have to assume you haven't done the scallop cut at the bottom of the bell housing. Makes life easier.
Re: TC bolt tightening sequence [Re: BDW] #3066218
08/08/22 12:48 PM
08/08/22 12:48 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Did you remove the starter? Straight shot on both sides of pan too. But that’s why we eventually just use a box wrench and screw driver to hold the ring gear.
Re: TC bolt tightening sequence [Re: moparx] #3066220
08/08/22 12:53 PM
08/08/22 12:53 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
beer
X3
I'll also do so with the flex plate if it's off or use another/ spare before install wink beer
Re: TC bolt tightening sequence [Re: CMcAllister] #3066302
08/08/22 05:51 PM
08/08/22 05:51 PM
BDW Offline OP
BDW  Offline OP
scalloped bell housing?
Its a 518, starter not installed, only bolts exposed are at bottom and blocked by oil pan, just not enough room to get a socket in there.
I understand why everyone mentioned using a wrench.
My bad not marking the orientation before starting.
I did mark it with a paint dab, but I really hope this thing never comes back apart.
To add insult to injury, the motor mounts pushed the whole assembly forward 1/4-1/2",
and that was just enough so that the trans mount no longer aligned.
Had to pull the trans cross member and increase the mounting holes for both the transmission cross member and trans mount to get to bolt together, what started out as a 1 hr project took me all day.
Re: TC bolt tightening sequence [Re: BDW] #3066321
08/08/22 07:12 PM
08/08/22 07:12 PM
A727Tflite Offline
A727Tflite  Offline
Something on this order - most guys make a square cut out - this pic is from a diesel or gas 618. Ignore the highlighted circles.
Re: TC bolt tightening sequence [Re: TJP] #3066525
08/09/22 12:44 PM
08/09/22 12:44 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
beer
X3
Same. Oldest trick in the book.
Rich H.
Esse Quam Videri
Re: TC bolt tightening sequence [Re: BDW] #3067044
08/11/22 11:44 AM
08/11/22 11:44 AM
"what started out as a 1 hr project took me all day."
you realize there is no such thing as a "1 hour" project ? laugh2
beer
Re: TC bolt tightening sequence [Re: moparx] #3067071
08/11/22 01:18 PM
08/11/22 01:18 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
beer
My wife thinks there are
Re: TC bolt tightening sequence [Re: cudaman1969] #3067086
08/11/22 02:10 PM
08/11/22 02:10 PM
beer
Ride Cowboy, Ride devil whistling grin
Re: TC bolt tightening sequence [Re: Cab_Burge] #3067279
08/12/22 09:40 AM
08/12/22 09:40 AM
that's only a 5 minute job, Cab. laugh2
well, once i get started, that is....................... whistling
beer
