Gen 3 Dominator Q. #3066040
08/07/22 01:16 PM
08/07/22 01:16 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Anyone know why there are 4 grub screws in the top of a Holley Gen 3 Dominator metering block (billet) ? They seem to be something to do with the intermediate and hi speed bleeds. The reason I ask is when I was cleaning these out with carb cleaner and an air line, I noticed they were leaking. Can I just screw these in or snug them up ? Some were backed out more than others but I've set them all flush with the top of the block (as the majority were) snugged up they go 1/16" in. My worry is these were used for fine tuning the above circuits but then again whats the point if you already have removable jets for this shruggy
Confused confused TIA up
Re: Gen 3 Dominator Q. [Re: Tig] #3066047
08/07/22 02:05 PM
08/07/22 02:05 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
No experience with those myself........ but leaking plugs in the metering block doesn’t sound great to me.
Re: Gen 3 Dominator Q. [Re: Tig] #3066172
08/08/22 09:50 AM
08/08/22 09:50 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
If you are referring to the 8-32 set screws tighten em up or remove em and re seal em....
Re: Gen 3 Dominator Q. [Re: Thumperdart] #3066200
08/08/22 11:19 AM
08/08/22 11:19 AM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
I think so, there are 8 per carb. They're on the top of the metering blocks (next to a pair of brass blanking brass blanking plugs). What are they for ?
