Gen 3 Dominator Q.
#3066040
08/07/22 01:16 PM
08/07/22 01:16 PM
Posts: 2,915 A shed in England
Tig
A shed in England
Anyone know why there are 4 grub screws in the top of a Holley Gen 3 Dominator metering block (billet) ? They seem to be something to do with the intermediate and hi speed bleeds. The reason I ask is when I was cleaning these out with carb cleaner and an air line, I noticed they were leaking. Can I just screw these in or snug them up ? Some were backed out more than others but I've set them all flush with the top of the block (as the majority were) snugged up they go 1/16" in. My worry is these were used for fine tuning the above circuits but then again whats the point if you already have removable jets for this Confused TIA
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: Gen 3 Dominator Q.
[Re: Tig]
#3066047
08/07/22 02:05 PM
08/07/22 02:05 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
No experience with those myself........ but leaking plugs in the metering block doesn’t sound great to me.
[Re: Tig]
#3066172
08/08/22 09:50 AM
08/08/22 09:50 AM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
If you are referring to the 8-32 set screws tighten em up or remove em and re seal em....
[Re: Thumperdart]
#3066200
08/08/22 11:19 AM
08/08/22 11:19 AM
Tig
A shed in England
If you are referring to the 8-32 set screws tighten em up or remove em and re seal em.... I think so, there are 8 per carb. They're on the top of the metering blocks (next to a pair of brass blanking brass blanking plugs). What are they for ?
