Like to see Underhood pictures of Airgrabber Cars w/A/C adde
#3065997
08/07/22 09:37 AM
08/07/22 09:37 AM
Posts: 6,224 JERSEY
RJS
JERSEY
As title states, I'd like to see underhood pictures of 71-2 B-Body's with A/C .
It would be great if anyone had an A/C car that was upgraded to the newer stuff underhood also. My car is a Non-Grabber w/A/C and really want more cooling and less drag so pictures of modern stuff would be helpful and any with Air Grabber baseplate would be really great!! Stories of how you went about running lines etc.. I really hate deviating from stock look but there are so many benefits to do so. I'll start off with a picture from Classic Air site. Ron
Re: Like to see Underhood pictures of Airgrabber Cars w/A/C adde
[Re: RJS]
#3066006
08/07/22 10:36 AM
08/07/22 10:36 AM
Posts: 4,566 Motor City
6PKRTSE
Motor City
Not an air grabber car. However, mine is an A/C sixpack car with factory compressor.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3066016
08/07/22 11:14 AM
08/07/22 11:14 AM
Posts: 6,224 JERSEY
RJS
JERSEY
Very nice!!! Can you share some pictures or advice about how much cutting was involved on your baseplate??
I plan on using a reproduction so I won't feel bad cutting and in actuality would also be cheaper to just go that route. I do wonder if anything would have to be modified on the underhood ducting though? I'd be using this set up with A/C... but a right side upper hose radiator Thanks Ron
[Re: RJS]
#3066030
08/07/22 12:17 PM
08/07/22 12:17 PM
Posts: 4,720 Moved to N.E. Tennessee
GomangoCuda
I cant say from experience since I have never owned one but this looks like a very potential problem area.
[Re: Jim_Lusk]
#3066160
08/08/22 08:27 AM
08/08/22 08:27 AM
Posts: 6,224 JERSEY
RJS
JERSEY
Not an air grabber car, but has the air cleaner with the neck cut down to fit under the hood of my '67 Barracuda convertible on top of the 440. Sanden compressor on Bouchillon brackets. And, yes that is a factory 383 air cleaner. So is the thinking even with a Sanden Compressor that sometimes the airfilter has to be notched? Ron
[Re: RJS]
#3066174
08/08/22 09:54 AM
08/08/22 09:54 AM
Posts: 983 rust belt
Moparite
rust belt
if you use our low mount ac kit you won't have any fitment issues. Who is "our" link, info? Are you referring to the Bouchillon brackets?
[Re: RJS]
#3066181
08/08/22 10:21 AM
08/08/22 10:21 AM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
Not an air grabber car, but has the air cleaner with the neck cut down to fit under the hood of my '67 Barracuda convertible on top of the 440. Sanden compressor on Bouchillon brackets. And, yes that is a factory 383 air cleaner. So is the thinking even with a Sanden Compressor that sometimes the airfilter has to be notched? Ron Ron , what car is that yellow one you posted in the original post, it has a sanden and the base does not look notched? I think if you stay with the RV2 compressor and have to notch the base you are going to have potential ductwork interference.
[Re: JohnRR]
#3066210
08/08/22 11:49 AM
08/08/22 11:49 AM
Posts: 6,224 JERSEY
RJS
JERSEY
Not an air grabber car, but has the air cleaner with the neck cut down to fit under the hood of my '67 Barracuda convertible on top of the 440. Sanden compressor on Bouchillon brackets. And, yes that is a factory 383 air cleaner. So is the thinking even with a Sanden Compressor that sometimes the airfilter has to be notched? Ron Ron , what car is that yellow one you posted in the original post, it has a sanden and the base does not look notched? I think if you stay with the RV2 compressor and have to notch the base you are going to have potential ductwork interference. hey John been a very long time how are you??? The yellow car is from the Classic Air site and yes I believe may not have to notch with Sandan Compressor. My engine is a low-deck 400 but it has a RPM manifold so I will go with a 440 setup because it's lower but really am wondering if ductwork area will be problematic and can't/won't be able to modify that stuff. I think you know me enough that the changeover under the hood is against my religion but have to have the AirGrabber to make this satellite like the first and have to have Cold A/C because I'm an old fart!!! Ron
[Re: RJS]
#3066387
08/08/22 09:51 PM
08/08/22 09:51 PM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
Not an air grabber car, but has the air cleaner with the neck cut down to fit under the hood of my '67 Barracuda convertible on top of the 440. Sanden compressor on Bouchillon brackets. And, yes that is a factory 383 air cleaner. So is the thinking even with a Sanden Compressor that sometimes the airfilter has to be notched? Ron Perhaps. There's more than an inch cut out of the neck on this air cleaner so it might fit in a car with a higher hood.
[Re: Jim_Lusk]
#3066394
08/08/22 10:16 PM
08/08/22 10:16 PM
Posts: 6,224 JERSEY
RJS
JERSEY
Not an air grabber car, but has the air cleaner with the neck cut down to fit under the hood of my '67 Barracuda convertible on top of the 440. Sanden compressor on Bouchillon brackets. And, yes that is a factory 383 air cleaner. So is the thinking even with a Sanden Compressor that sometimes the airfilter has to be notched? Ron Perhaps. There's more than an inch cut out of the neck on this air cleaner so it might fit in a car with a higher hood. Jim that's why they cut the neck to make a 383 baseplate more like a 440 baseplate. Ron
[Re: RJS]
#3066472
08/09/22 09:32 AM
08/09/22 09:32 AM
JohnRR
U.S.S.A.
Not an air grabber car, but has the air cleaner with the neck cut down to fit under the hood of my '67 Barracuda convertible on top of the 440. Sanden compressor on Bouchillon brackets. And, yes that is a factory 383 air cleaner. So is the thinking even with a Sanden Compressor that sometimes the airfilter has to be notched? Ron Ron , what car is that yellow one you posted in the original post, it has a sanden and the base does not look notched? I think if you stay with the RV2 compressor and have to notch the base you are going to have potential ductwork interference. hey John been a very long time how are you??? The yellow car is from the Classic Air site and yes I believe may not have to notch with Sandan Compressor. My engine is a low-deck 400 but it has a RPM manifold so I will go with a 440 setup because it's lower but really am wondering if ductwork area will be problematic and can't/won't be able to modify that stuff. I think you know me enough that the changeover under the hood is against my religion but have to have the AirGrabber to make this satellite like the first and have to have Cold A/C because I'm an old fart!!! Ron The low deck will gain you about 3/4" clearance to the hood, couple that with a Sanden compressor and you should clear the ductwork just fine. Also the RPM manifold will also help you clear the Sanden compressor. I'm doing ok , just getting back to it after a long hiatus.
[Re: RJS]
#3066960
08/10/22 11:39 PM
08/10/22 11:39 PM
Jim_Lusk
Fresno, CA
Not an air grabber car, but has the air cleaner with the neck cut down to fit under the hood of my '67 Barracuda convertible on top of the 440. Sanden compressor on Bouchillon brackets. And, yes that is a factory 383 air cleaner. So is the thinking even with a Sanden Compressor that sometimes the airfilter has to be notched? Ron Perhaps. There's more than an inch cut out of the neck on this air cleaner so it might fit in a car with a higher hood. Jim that's why they cut the neck to make a 383 baseplate more like a 440 baseplate. Ron This is cut far more than the difference between stock 383 and 440 base plates. I borrowed a 440 base plate many years ago to see if it would work with the 440 in my old Dart. With no gaskets on a core engine the lid hit the hood so I gave up looking for the rarer and more expensive 440 single four barrel air cleaner.
[Re: Jim_Lusk]
#3067027
08/11/22 10:53 AM
08/11/22 10:53 AM
JohnRR
U.S.S.A.
Not an air grabber car, but has the air cleaner with the neck cut down to fit under the hood of my '67 Barracuda convertible on top of the 440. Sanden compressor on Bouchillon brackets. And, yes that is a factory 383 air cleaner. So is the thinking even with a Sanden Compressor that sometimes the airfilter has to be notched? Ron Perhaps. There's more than an inch cut out of the neck on this air cleaner so it might fit in a car with a higher hood. Jim , what intake did you use ?
[Re: JohnRR]
#3067185
08/11/22 09:25 PM
08/11/22 09:25 PM
Jim_Lusk
Fresno, CA
Not an air grabber car, but has the air cleaner with the neck cut down to fit under the hood of my '67 Barracuda convertible on top of the 440. Sanden compressor on Bouchillon brackets. And, yes that is a factory 383 air cleaner. So is the thinking even with a Sanden Compressor that sometimes the airfilter has to be notched? Ron Perhaps. There's more than an inch cut out of the neck on this air cleaner so it might fit in a car with a higher hood. Jim , what intake did you use ? Factory 1967 440.
