Like to see Underhood pictures of Airgrabber Cars w/A/C adde #3065997
08/07/22 09:37 AM
08/07/22 09:37 AM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
As title states, I'd like to see underhood pictures of 71-2 B-Body's with A/C .
It would be great if anyone had an A/C car that was upgraded to the newer stuff underhood also.
My car is a Non-Grabber w/A/C and really want more cooling and less drag so pictures of modern stuff would be helpful and any with Air Grabber baseplate would be really great!!
Stories of how you went about running lines etc.. I really hate deviating from stock look but there are so many benefits to do so.
I'll start off with a picture from Classic Air site.
Ron
IMG_1654.JPG0020198_71-72-charger-70-74-barracuda-big-block-ac-upgrade-kit-stage-1.jpeg
Re: Like to see Underhood pictures of Airgrabber Cars w/A/C adde [Re: RJS] #3066006
08/07/22 10:36 AM
08/07/22 10:36 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Not an air grabber car. However, mine is an A/C sixpack car with factory compressor.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Like to see Underhood pictures of Airgrabber Cars w/A/C adde [Re: 6PKRTSE] #3066016
08/07/22 11:14 AM
08/07/22 11:14 AM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
Very nice!!! Can you share some pictures or advice about how much cutting was involved on your baseplate??
I plan on using a reproduction so I won't feel bad cutting and in actuality would also be cheaper to just go that route.
I do wonder if anything would have to be modified on the underhood ducting though?
I'd be using this set up with A/C... but a right side upper hose radiator
Thanks Ron
Re: Like to see Underhood pictures of Airgrabber Cars w/A/C adde [Re: RJS] #3066030
08/07/22 12:17 PM
08/07/22 12:17 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I cant say from experience since I have never owned one but this looks like a very potential problem area.
Re: Like to see Underhood pictures of Airgrabber Cars w/A/C adde [Re: GomangoCuda] #3066038
08/07/22 01:01 PM
08/07/22 01:01 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
if you use our low mount ac kit you won't have any fitment issues.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Like to see Underhood pictures of Airgrabber Cars w/A/C adde [Re: Jerry] #3066121
08/07/22 09:08 PM
08/07/22 09:08 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Not an air grabber car, but has the air cleaner with the neck cut down to fit under the hood of my '67 Barracuda convertible on top of the 440. Sanden compressor on Bouchillon brackets. And, yes that is a factory 383 air cleaner.
Re: Like to see Underhood pictures of Airgrabber Cars w/A/C adde [Re: Jim_Lusk] #3066160
08/08/22 08:27 AM
08/08/22 08:27 AM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
So is the thinking even with a Sanden Compressor that sometimes the airfilter has to be notched?
Ron
Re: Like to see Underhood pictures of Airgrabber Cars w/A/C adde [Re: RJS] #3066174
08/08/22 09:54 AM
08/08/22 09:54 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Quote
Who is "our" link, info? Are you referring to the Bouchillon brackets?
Re: Like to see Underhood pictures of Airgrabber Cars w/A/C adde [Re: RJS] #3066181
08/08/22 10:21 AM
08/08/22 10:21 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Ron
Ron , what car is that yellow one you posted in the original post, it has a sanden and the base does not look notched?
I think if you stay with the RV2 compressor and have to notch the base you are going to have potential ductwork interference.
Re: Like to see Underhood pictures of Airgrabber Cars w/A/C adde [Re: JohnRR] #3066210
08/08/22 11:49 AM
08/08/22 11:49 AM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
Ron
hey John been a very long time how are you???
The yellow car is from the Classic Air site and yes I believe may not have to notch with Sandan Compressor.
My engine is a low-deck 400 but it has a RPM manifold so I will go with a 440 setup because it's lower but really am wondering if ductwork area will be problematic and can't/won't be able to modify that stuff.
I think you know me enough that the changeover under the hood is against my religion but have to have the AirGrabber to make this satellite like the first and have to have Cold A/C because I'm an old fart!!!
Ron
Re: Like to see Underhood pictures of Airgrabber Cars w/A/C adde [Re: RJS] #3066232
08/08/22 01:49 PM
08/08/22 01:49 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
superior design concepts makes the low mount ac kit
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: Like to see Underhood pictures of Airgrabber Cars w/A/C adde [Re: Jerry] #3066249
08/08/22 02:31 PM
08/08/22 02:31 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
That's pretty for a hotrod or custom.
Ron
Re: Like to see Underhood pictures of Airgrabber Cars w/A/C adde [Re: RJS] #3066261
08/08/22 03:11 PM
08/08/22 03:11 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
alot of guys run them anodized black and you can hardly tell its not factory.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: Like to see Underhood pictures of Airgrabber Cars w/A/C adde [Re: RJS] #3066387
08/08/22 09:51 PM
08/08/22 09:51 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Ron
Perhaps. There's more than an inch cut out of the neck on this air cleaner so it might fit in a car with a higher hood.
Re: Like to see Underhood pictures of Airgrabber Cars w/A/C adde [Re: Jim_Lusk] #3066394
08/08/22 10:16 PM
08/08/22 10:16 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
Ron
Jim that's why they cut the neck to make a 383 baseplate more like a 440 baseplate.
Ron
Re: Like to see Underhood pictures of Airgrabber Cars w/A/C adde [Re: RJS] #3066472
08/09/22 09:32 AM
08/09/22 09:32 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Ron
Ron
The low deck will gain you about 3/4" clearance to the hood, couple that with a Sanden compressor and you should clear the ductwork just fine. Also the RPM manifold will also help you clear the Sanden compressor.
I'm doing ok , just getting back to it after a long hiatus.
Re: Like to see Underhood pictures of Airgrabber Cars w/A/C adde [Re: RJS] #3066960
08/10/22 11:39 PM
08/10/22 11:39 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Ron
Ron
This is cut far more than the difference between stock 383 and 440 base plates. I borrowed a 440 base plate many years ago to see if it would work with the 440 in my old Dart. With no gaskets on a core engine the lid hit the hood so I gave up looking for the rarer and more expensive 440 single four barrel air cleaner.
Re: Like to see Underhood pictures of Airgrabber Cars w/A/C adde [Re: Jim_Lusk] #3067027
08/11/22 10:53 AM
08/11/22 10:53 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Ron
Jim , what intake did you use ?
Re: Like to see Underhood pictures of Airgrabber Cars w/A/C adde [Re: JohnRR] #3067185
08/11/22 09:25 PM
08/11/22 09:25 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Ron
Factory 1967 440.
