Carb identification? #3065979
08/07/22 08:30 AM
08/07/22 08:30 AM
Finalnd, Perkele
jyrki Offline OP
jyrki  Offline OP
Finalnd, Perkele
Anyone recognize this carburetor I have in my car. It has absolutely no markings anywhere. It seems like it's anodized gold, and is a typical Holley style. The fuel inlets are the same as in some Demons I think. With blind power valves and to me seemingly large 91 & 93 jets.
Plynouth VIP '67 TT IC EFI
Re: Carb identification? [Re: jyrki] #3065980
08/07/22 08:37 AM
08/07/22 08:37 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
looks like a speedmaster
Re: Carb identification? [Re: jyrki] #3065981
08/07/22 08:37 AM
08/07/22 08:37 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
I've never seen one in person but I believe this to be a "Pro Comp" carb, Chinese version of a 4150.
Speedmaster appears not to have the screw in bleeds, but again I have no experience with either shruggy
Re: Carb identification? [Re: Tig] #3065983
08/07/22 08:53 AM
08/07/22 08:53 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I thought procomp and speedmaster was the same company shruggy
Re: Carb identification? [Re: B1MAXX] #3065985
08/07/22 09:06 AM
08/07/22 09:06 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Correct, Procomp changed their name to speedmaster around 2014.
Re: Carb identification? [Re: Tig] #3065987
08/07/22 09:13 AM
08/07/22 09:13 AM
Finalnd, Perkele
jyrki Offline OP
jyrki  Offline OP
Finalnd, Perkele
Thanks! Seems like one. There doesn't seem to be any numbers anywhere, so it's kind of hard to judge what kind of jets should be in there. The size is supposed to be 850, but I have no idea weather it's true or not. Anyway, for that size, 91&93 jets seems awfully big, and according to the plugs it runs rich = black plugs. And the idle screws can only be open about 1/4 turn or it's too rich. I think I'll drop the jet sizes 3 in the rear and 10 in front, and install a power valve in front. See how that affects the idle, or do I have to try to change the idle air bleeds to bigger size.
Re: Carb identification? [Re: jyrki] #3065992
08/07/22 09:26 AM
08/07/22 09:26 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Jetting won't effect idle circuits.
Re: Carb identification? [Re: B1MAXX] #3066015
08/07/22 11:13 AM
08/07/22 11:13 AM
Cab_Burge Online work
Cab_Burge  Online Work
Shouldn't affect the idle circuit UNLESS the throttle plates are open far enough to expose the transition circuits on some carbs shruggy scope
Re: Carb identification? [Re: Cab_Burge] #3066027
08/07/22 12:04 PM
08/07/22 12:04 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Transition slots are still from idle circuit. Idle feed restriction is the only "jet"on that side.
Re: Carb identification? [Re: B1MAXX] #3066050
08/07/22 02:17 PM
08/07/22 02:17 PM
Finalnd, Perkele
jyrki Offline OP
jyrki  Offline OP
Finalnd, Perkele
Ok. Anyway, I'll put in smaller jets all around + the power valve. Then I think again if I want to play with the idle restrictions. I think it was way too rich overall. Next weekend we'll see how it reacts, weather permitting.
