Re: Hemi rockers
[Re: Dragula]
#3065207
08/04/22 03:00 PM
08/04/22 03:00 PM
Posts: 17,912 S.E. Michigan
ZIPPY
S.E. Michigan
Not just show poodling it around at cruise nights and car shows
TBH, personally at this point having one in a car that runs at all and moves under it's own power will be plenty enough of an accomplishment, let alone attending any kind of event. I don't intend to join the straw hat and lawnchair crowd anytime soon. It could happen later, but pretty unlikely.
Rich H.
Esse Quam Videri
Re: Hemi rockers
[Re: ZIPPY]
#3065210
08/04/22 03:09 PM
08/04/22 03:09 PM
fast68plymouth
So. Burlington, Vt.
If there were only some way to determine who someone would contact to get a set of these.......
Re: Hemi rockers
[Re: ZIPPY]
#3065235
08/04/22 03:55 PM
08/04/22 03:55 PM
Posts: 4,584 Motor City
6PKRTSE
Motor City
Anything Manton makes is a good quality part.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
Re: Hemi rockers
[Re: ZIPPY]
#3066192
08/08/22 11:00 AM
08/08/22 11:00 AM
Posts: 75,094 A Banana Republic near you.
JohnRR
And then, there’s these. Nobody here ever brings them up I wondered if Manton made some after seeing what Steve Morris had made for by them.
Re: Hemi rockers
[Re: fast68plymouth]
#3066250
08/08/22 02:35 PM
08/08/22 02:35 PM
Posts: 43,300 Bend,OR USA
Cab_Burge
If there were only some way to determine who someone would contact to get a set of these....... This set does not look like it fits the 426 street hemi motors I wonder which brand Hemi heads they fit on?
Re: Hemi rockers
[Re: Cab_Burge]
#3066254
08/08/22 02:41 PM
08/08/22 02:41 PM
Posts: 2,678 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
If there were only some way to determine who someone would contact to get a set of these....... This set does not look like it fits the 426 street hemi motors I wonder which brand Hemi heads they fit on? Those are for blown hemi motors with aftermarket heads. Several variations of those. No use for a Street Hemi guy.
2011 Drag Pak Challenger
Re: Hemi rockers
[Re: rickseeman]
#3066266
08/08/22 03:29 PM
08/08/22 03:29 PM
ZIPPY
S.E. Michigan
But wouldn't they make them for a street hemi, if someone threw enough money in their general direction?
Rich H.
Esse Quam Videri
Re: Hemi rockers
[Re: ZIPPY]
#3066267
08/08/22 03:31 PM
08/08/22 03:31 PM
Posts: 4,103 Yes
sixpakdodge
Yes
But wouldn't they make them for a street hemi, if someone threw enough money in their general direction? If you check their website, they already do...but with all the crying about Barton/T&D's, I'd advise you guys not to look...
Re: Hemi rockers
[Re: LAD 524]
#3067135
08/11/22 06:55 PM
08/11/22 06:55 PM
Posts: 3,505 DFW
mr_340
DFW
Manton has a Faceboogie page and they say they use tool steel for almost everything. They don't say which tool steel or what the heat treatment/hardness they have. I suspect it's A2, but I haven't been able to squeeze anymore info out of them. I've heard the Jesel SS rocker arm kit is about $6k and there is three or more versions of them.
Floyd Lippencott IV
Re: Hemi rockers
[Re: mr_340]
#3067181
08/11/22 09:19 PM
08/11/22 09:19 PM
Cab_Burge
Manton has a Faceboogie page and they say they use tool steel for almost everything. They don't say which tool steel or what the heat treatment/hardness they have. I suspect it's A2, but I haven't been able to squeeze anymore info out of them. I've heard the Jesel SS rocker arm kit is about $6k and there is three or more versions of them. Any part for Hemiroid motor is never cheap, good parts costs a lot more money than the cheaper ones, but you may save money in the long run by buying the good ones to start with: up: work:
Re: Hemi rockers
[Re: MoonshineMattK]
#3070683
08/23/22 08:39 AM
08/23/22 08:39 AM
Posts: 1,629 pa
572charger
pa
yes im glad i did by the ray barton stuff in 2003, almost 20 yrs of beating the crap out of them on the street and track no wear at all, and the valve springs last because of all the oil being sprayed in the valve cover ,730 lift roller, cam and at least 12000 miles on the rockers and pushrods best investment for my hemi and they never come out of adjustment set um and forget um lol
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Hemi rockers
[Re: 572charger]
#3070691
08/23/22 09:48 AM
08/23/22 09:48 AM
Posts: 13,400 Marion, South Carolina [><]
an8sec70cuda
I have a much cheaper setup. Older DLI roller rockers w/ MP shafts and aluminum stands. Been using mine since 2006 (street/strip) and never had any issues other than typical valve guide and stem wear. In the 850 hp ballpark NA and 1150+ hp or so on nitrous. I don't go much above 7k RPM and I have a pretty mild solid roller cam in it. Is the Barton setup much easier on valve guides? I always felt like unless you're turning 8k+ RPM, then the Barton setup is nice, but not of any real benefit...unless the geometry is improved enough to where there's a real difference in valve guide wear.
Re: Hemi rockers
[Re: an8sec70cuda]
#3070741
08/23/22 12:06 PM
08/23/22 12:06 PM
Posts: 154 Canada
cuda499
Canada
I have a much cheaper setup. Older DLI roller rockers w/ MP shafts and aluminum stands. Been using mine since 2006 (street/strip) and never had any issues other than typical valve guide and stem wear. In the 850 hp ballpark NA and 1150+ hp or so on nitrous. I don't go much above 7k RPM and I have a pretty mild solid roller cam in it. Is the Barton setup much easier on valve guides? I always felt like unless you're turning 8k+ RPM, then the Barton setup is nice, but not of any real benefit...unless the geometry is improved enough to where there's a real difference in valve guide wear. Billet stands that tie into center head bolts, Individual stands for each rocker, Each stand adjustable height for each rocker..... was enough to sell me. Before the barton rockers, i had an old school Norris steel rocker on a Indy 1-RA head and they worked good as well. Shifted it at between 7700-8000
