Page 2 of 3 1 2 3
Re: Hemi rockers [Re: ZIPPY] #3065121
08/04/22 10:52 AM
08/04/22 10:52 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Originally Posted by ZIPPY
And then, there’s these. Nobody here ever brings them up
Do they come in blue?
Re: Hemi rockers [Re: Dragula] #3065207
08/04/22 03:00 PM
08/04/22 03:00 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Originally Posted by Dragula
Not just show poodling it around at cruise nights and car shows
TBH, personally at this point having one in a car that runs at all and moves under it's own power will be plenty enough of an accomplishment,
let alone attending any kind of event.
I don't intend to join the straw hat and lawnchair crowd anytime soon. It could happen later, but pretty unlikely.
Rich H.
Esse Quam Videri
Re: Hemi rockers [Re: ZIPPY] #3065210
08/04/22 03:09 PM
08/04/22 03:09 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
If there were only some way to determine who someone would contact to get a set of these.......
Re: Hemi rockers [Re: fast68plymouth] #3065214
08/04/22 03:20 PM
08/04/22 03:20 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
haha
Rich H.
Esse Quam Videri
Re: Hemi rockers [Re: ZIPPY] #3065235
08/04/22 03:55 PM
08/04/22 03:55 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Anything Manton makes is a good quality part.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Hemi rockers [Re: fast68plymouth] #3065323
08/04/22 09:13 PM
08/04/22 09:13 PM
I ask them several years ago to make some for BB, not yet whiney
Re: Hemi rockers [Re: ZIPPY] #3066192
08/08/22 11:00 AM
08/08/22 11:00 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I wondered if Manton made some after seeing what Steve Morris had made for by them.
Re: Hemi rockers [Re: fast68plymouth] #3066250
08/08/22 02:35 PM
08/08/22 02:35 PM
This set does not look like it fits the 426 street hemi motors work scope
I wonder which brand Hemi heads they fit on? work
Re: Hemi rockers [Re: Cab_Burge] #3066254
08/08/22 02:41 PM
08/08/22 02:41 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Those are for blown hemi motors with aftermarket heads. Several variations of those. No use for a Street Hemi guy.
2011 Drag Pak Challenger
Re: Hemi rockers [Re: rickseeman] #3066266
08/08/22 03:29 PM
08/08/22 03:29 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
But wouldn't they make them for a street hemi, if someone threw enough money in their general direction?
Rich H.
Esse Quam Videri
Re: Hemi rockers [Re: ZIPPY] #3066267
08/08/22 03:31 PM
08/08/22 03:31 PM
W. PA
sixpakdodge Offline
sixpakdodge  Offline
W. PA
If you check their website, they already do...but with all the crying about Barton/T&D's, I'd advise you guys not to look...
Re: Hemi rockers [Re: sixpakdodge] #3066279
08/08/22 04:10 PM
08/08/22 04:10 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
As Gomer Pyle used to say: Shazam.
Rich H.
Esse Quam Videri
Re: Hemi rockers [Re: ZIPPY] #3066429
08/09/22 01:07 AM
08/09/22 01:07 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Or these...... grin
https://reidmachine.com/shop/ols/products/high-ratio-exhaust-roller-rocker-arm
I need some Exh rockers...will likely go with Stage V.
Re: Hemi rockers [Re: LAD 524] #3067135
08/11/22 06:55 PM
08/11/22 06:55 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Manton has a Faceboogie page and they say they use tool steel for almost everything. They don't say which tool steel or what the heat treatment/hardness they have. I suspect it's A2, but I haven't been able to squeeze anymore info out of them. I've heard the Jesel SS rocker arm kit is about $6k and there is three or more versions of them.
Floyd Lippencott IV
Re: Hemi rockers [Re: mr_340] #3067181
08/11/22 09:19 PM
08/11/22 09:19 PM
Any part for Hemiroid motor is never cheap, good parts costs a lot more money than the cheaper ones, but you may save money in the long run by buying the good ones to start with: up: work: work
Re: Hemi rockers [Re: Cab_Burge] #3069320
08/18/22 06:02 PM
08/18/22 06:02 PM
Canada
cuda499 Offline
cuda499  Offline
Canada
Barton has sold over 1000 sets of his rocker system without many issues. When I built my last hemi, there was no question i was buying his. The adjustability, stand height, solid billet mount that uses the head studs to hold it down... To me it was the system you want, when you wanna buzz one to or past 8000 rpm.
Re: Hemi rockers [Re: cuda499] #3069729
08/19/22 10:06 PM
08/19/22 10:06 PM
NW Illinois
MoonshineMattK Offline
NW Illinois
No HEMI experience but love reading about the engines. Many times on this forum I've read people post that they wished the had just ponied up and got the Barton rockers the 1st time.
Re: Hemi rockers [Re: MoonshineMattK] #3070683
08/23/22 08:39 AM
08/23/22 08:39 AM
pa
572charger Offline
572charger  Offline
pa
yes im glad i did by the ray barton stuff in 2003, almost 20 yrs of beating the crap out of them on the street and track no wear at all, and the valve springs last because of all the oil being sprayed in the valve cover ,730 lift roller, cam and at least 12000 miles on the rockers and pushrods best investment for my hemi and they never come out of adjustment set um and forget um lol
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Hemi rockers [Re: 572charger] #3070691
08/23/22 09:48 AM
08/23/22 09:48 AM
an8sec70cuda Offline
I have a much cheaper setup. Older DLI roller rockers w/ MP shafts and aluminum stands. Been using mine since 2006 (street/strip) and never had any issues other than typical valve guide and stem wear. In the 850 hp ballpark NA and 1150+ hp or so on nitrous. I don't go much above 7k RPM and I have a pretty mild solid roller cam in it.
Is the Barton setup much easier on valve guides? shruggy I always felt like unless you're turning 8k+ RPM, then the Barton setup is nice, but not of any real benefit...unless the geometry is improved enough to where there's a real difference in valve guide wear. shruggy
CHIP
'70 hemicuda...8 sec street car
'69 road runner 440-6, 4 speed
'71 Demon 340
'73 Chrysler New Yorker
'90 Chevy 454SS Silverado
'06 GMC 2500HD LBZ Duramax...toy hauler
Re: Hemi rockers [Re: an8sec70cuda] #3070741
08/23/22 12:06 PM
08/23/22 12:06 PM
Canada
cuda499 Offline
cuda499  Offline
Canada
Billet stands that tie into center head bolts, Individual stands for each rocker, Each stand adjustable height for each rocker..... was enough to sell me. Before the barton rockers, i had an old school Norris steel rocker on a Indy 1-RA head and they worked good as well. Shifted it at between 7700-8000
Page 2 of 3 1 2 3
