Re: Hemi Spark plug tubes [Re: cudaman1969] #3063042
07/27/22 03:36 PM
07/27/22 03:36 PM
Originally Posted by cudaman1969
Just use the oil plug nylon washer,
work up
Re: Hemi Spark plug tubes [Re: cudaman1969] #3063129
07/27/22 09:26 PM
07/27/22 09:26 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
What's an oil plug nylon washer ? do you mean a drain plug washer? Will they take the heat without losing their rigidity? If not there are likely other plastics that probably would.
HMM maybe a good idea up shruggy
Re: Hemi Spark plug tubes [Re: TJP] #3063132
07/27/22 09:39 PM
07/27/22 09:39 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Yes, what I meant. Not sure how much heat is right there but I would say no more the hot oil in the pan, 250 degrees?
Re: Hemi Spark plug tubes [Re: cudaman1969] #3063938
07/30/22 06:59 PM
07/30/22 06:59 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
OK.....got it running great with no smoke or sputtering on startup. Carb choke was misadjusted and when taken out...hemi starts fine with no smoke or sputtering. Oil not leaking into cylinders from tubes...Thanks to all.....BUT....there is a gremlin in My garage...about 6 weeks ago I noticed an oil spot on the floor and it was a slightly loose oil plug. New pan so I tightened it up just like I have done on every oil change since 1966. Today when going to work the car there was about a quart of oil under and all over My floor. VERY loose oil pan plug...tightened..AGAIN and will keep an eye on it.
Re: Hemi Spark plug tubes [Re: terzmo] #3064098
07/31/22 02:58 PM
07/31/22 02:58 PM
moparx Offline
moparx  Offline
what kind of gasket is on the drain plug ? if none, could one be installed ?
beer
Re: Hemi Spark plug tubes [Re: moparx] #3064233
08/01/22 08:04 AM
08/01/22 08:04 AM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
Just the one it came with.....someone mentioned to use loctite 518 on the back side of the washer.
Re: Hemi Spark plug tubes [Re: terzmo] #3064257
08/01/22 10:13 AM
08/01/22 10:13 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
These are nice:
https://www.dormanproducts.com/p-19490-090-058.aspx
Alternately we can also take a cue from German car service and add a copper crush washer to the existing plug.
Rich H.
Esse Quam Videri
Re: Hemi Spark plug tubes [Re: ZIPPY] #3064618
08/02/22 12:15 PM
08/02/22 12:15 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by ZIPPY
These are nice:
The dorman's doo look nice. I've been using these GASKET ASST. LINKY And have taken to wrapping the plug threads with teflon tape
Shop on the suggested kits if you go that way as the price varies wink
Re: Hemi Spark plug tubes [Re: ZIPPY] #3064661
08/02/22 02:12 PM
08/02/22 02:12 PM
These are nice:
All the early, pre 1965 maybe, Mopar oil pan drain plugs had a copper composition washer with some type of white colored (maybe asbestos) material wrapped inside the washer on them scope
Re: Hemi Spark plug tubes [Re: Cab_Burge] #3065035
08/03/22 09:50 PM
08/03/22 09:50 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I believe they used those into the mid 70's or so. I had a friend who was a lube jockey at the local dealership. he gave me about 500 of them ~ 25 years ago, I'm down to just a few frown never had a leak with one up
Re: Hemi Spark plug tubes [Re: TJP] #3065082
08/04/22 08:47 AM
08/04/22 08:47 AM
VA
dragon slayer Offline
VA
These are nice:
Are we still talking spark plugs or have you shifted to oil plugs? Please tell me you don't teflon wrap spark plugs eek
Re: Hemi Spark plug tubes [Re: dragon slayer] #3065119
08/04/22 10:44 AM
08/04/22 10:44 AM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
shifted to oil pan plug that keeps backing out then leaks...doesn't leak when tight but so far refuses to stay tight after a few rides
Re: Hemi Spark plug tubes [Re: dragon slayer] #3065141
08/04/22 11:54 AM
08/04/22 11:54 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
These are nice:
Sure do, keeps them from making a good ground to the cylinder head and is great for comebacks, then i can upgrade the plug wires and other things beer laugh2
back to the drain plug, any chance you have a 12mm x 1.75 bolt n a 1/2x20 opening? I ask as they are close diameter and pitch wise, may mate and tighten but with little thread engagement. In over 50 years I have never encountered a drain plug that kept loosening. shruggy
Re: Hemi Spark plug tubes [Re: TJP] #3065185
08/04/22 02:24 PM
08/04/22 02:24 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I use them on my early Hemi
Abe Lincoln
Re: Hemi Spark plug tubes [Re: dart4forte] #3065200
08/04/22 02:48 PM
08/04/22 02:48 PM
426 hemi tubes in an early Chrysler Fire Power 331,354 392 C.I.? work
Please let us know, that could solve a problem in a different way than I would have thought of work luck
Re: Hemi Spark plug tubes [Re: TJP] #3065232
08/04/22 03:53 PM
08/04/22 03:53 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
These are nice:
Using the plug that came with the pan
Re: Hemi Spark plug tubes [Re: terzmo] #3065316
08/04/22 09:02 PM
08/04/22 09:02 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Depending on a number of variables like where the pan and its parts originated from you may have a tolerance stack up issue or poor QC.
I would suggest trying a longer GOOD QUALITY 1/2-20 bolt to see how snug or loose it is in the pan threads. If it's too loose you could go to an oversize plug to resolve the issue. I don't like suggesting that but something is not right and it needs to be identified and remedied. beer
Re: Hemi Spark plug tubes [Re: TJP] #3065426
08/05/22 10:07 AM
08/05/22 10:07 AM
fredericksburg,va
fredericksburg,va
Could be metric threads in the pan or plug, sometimes the two sizes are real close. Just had that problem replacing blade bolts on my finish mower. Thought they were 5/8 “ course but they were 16 mm. If it wasn’t for the nut and bolt guides on top of the bolt cabinet I wouldn’t have noticed the difference.
Re: Hemi Spark plug tubes [Re: cudaman1969] #3065446
08/05/22 11:17 AM
08/05/22 11:17 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree it could be either the plug itself or the threads in the pan or possibly both
I have run into this a few times as well along with other QC issues.
TO the OP: FYI 20 TPI is real close to 1.25mm TPI which is 20.32 TPI.
A 12mm bolt is about .472 and a 12.5mm is .492. the 12.5 is a bit uncommon but available in a bolt. Not sure on the drain plug though.
