Adapters for wheels to fit the axle/spindle register #3064277
08/01/22 10:57 AM
08/01/22 10:57 AM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Had a highway noise/vibration on our 70 Charger the we found to be
from the Americn Wheels not having the correct I.D. for our car.
Had these on for years, but never noticed before, (luck)?
Just assembled again due to a pumpkin change.
Anyhow, is there a source for these adaptors to assure concentricity?
Thanks, Joe
Re: Adapters for wheels to fit the axle/spindle register [Re: jlatessa] #3064284
08/01/22 11:06 AM
08/01/22 11:06 AM
AndyF Offline
AndyF  Offline
Yes, you can find a variety of hub adapters if you search for them. You may not find exactly what you need, but there are dozens of little anodized adapter rings available for sale from various sources.
Re: Adapters for wheels to fit the axle/spindle register [Re: AndyF] #3064291
08/01/22 11:13 AM
08/01/22 11:13 AM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Thanks Andy, I did a search and found suppliers easily.
I'll need to get a pair of inside calipers because my 6" Mitutoyos won't fit inside the wheel.
Sometimes the old tools are indispensable.
Thanks again, Joe
Re: Adapters for wheels to fit the axle/spindle register [Re: AndyF] #3064294
08/01/22 11:21 AM
08/01/22 11:21 AM
moparx Offline
moparx  Offline
here is a place to start.
https//us.hubcentric-rings.com/
i think e-bag and amazon also lists hubcentric rings as well.
i think all are listed in mm, so you may have to convert mm to inch measurement if you don't know what mm your hub od and wheel id are.
depending on the combination, you may have to get the closest ring available and trim the od or id, maybe even both, to get the proper fitment.
beer
Re: Adapters for wheels to fit the axle/spindle register [Re: moparx] #3064627
08/02/22 12:45 PM
08/02/22 12:45 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
beer
LINKY smile
fixed it for ya' wink I'd go for the aluminum if you can get them smile
Re: Adapters for wheels to fit the axle/spindle register [Re: TJP] #3064656
08/02/22 01:56 PM
08/02/22 01:56 PM
moparx Offline
moparx  Offline
thanks for the link fix. up
i just copied the address from my book marked page.
i vote for the aluminum as well, if possible.
beer
Re: Adapters for wheels to fit the axle/spindle register [Re: moparx] #3064818
08/03/22 07:51 AM
08/03/22 07:51 AM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Thanks guys, I have the plastic ones coming, I'll have to massage them a bit to compensate
for the dress-up caps (which my son reminded me about), grrr
Joe
Re: Adapters for wheels to fit the axle/spindle register [Re: jlatessa] #3064952
08/03/22 02:58 PM
08/03/22 02:58 PM
Those cast wheels usually center off of the lug nuts, not the inner wheel centers scope
Re: Adapters for wheels to fit the axle/spindle register [Re: Cab_Burge] #3065010
08/03/22 07:29 PM
08/03/22 07:29 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Mag wheels that can accept ET style lug nuts are worth using. The lug nut shanks go into the wheel hole and holds it all equal the full 360, which is a good thing. Not a lot of companies drill them to this size anymore though.
Re: Adapters for wheels to fit the axle/spindle register [Re: Neil] #3066573
08/09/22 02:45 PM
08/09/22 02:45 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Wheels are steel, re-ordered correct size, hopefully I did my computations correctly
this time.....
Joe
