Re: Adapters for wheels to fit the axle/spindle register
[Re: AndyF]
#3064294
08/01/22 11:21 AM
08/01/22 11:21 AM
Posts: 19,383 north of coder
moparx
here is a place to start. https//us.hubcentric-rings.com/ i think e-bag and amazon also lists hubcentric rings as well. i think all are listed in mm, so you may have to convert mm to inch measurement if you don't know what mm your hub od and wheel id are. depending on the combination, you may have to get the closest ring available and trim the od or id, maybe even both, to get the proper fitment.
[Re: moparx]
#3064627
08/02/22 12:45 PM
08/02/22 12:45 PM
Posts: 15,343 Omaha Ne
TJP
Omaha Ne
here is a place to start. https//us.hubcentric-rings.com/ i think e-bag and amazon also lists hubcentric rings as well. i think all are listed in mm, so you may have to convert mm to inch measurement if you don't know what mm your hub od and wheel id are. depending on the combination, you may have to get the closest ring available and trim the od or id, maybe even both, to get the proper fitment. LINKY fixed it for ya' I'd go for the aluminum if you can get them
[Re: moparx]
#3064818
08/03/22 07:51 AM
08/03/22 07:51 AM
Posts: 1,317 Ohio
jlatessa
Ohio
Thanks guys, I have the plastic ones coming, I'll have to massage them a bit to compensate for the dress-up caps (which my son reminded me about), grrr
Joe
