What offset dials do I need?
#3064107
07/31/22 04:13 PM
07/31/22 04:13 PM
Posts: 732 eastern,Ky
70RT Charger
eastern,Ky
Was having starter issues with my T-56 Magnum and asked my installer after the matter of the fact about dialing in the bellhousing. He said that he didn’t, lucky me. Any how I had a little accident with the car so decided to repaint it all and drop the K-frame. This is what I have right now. I understand that I need 14 offset dials for 12 and 6 but I haven’t seen a video about the 3 and 9 index being off speck like mine is. Could somebody help me understand and tell me what dials I need since I’m out of spec at both indexes. Thanks!!!
Re: What offset dials do I need?
[Re: Cab_Burge]
#3064116
07/31/22 04:55 PM
07/31/22 04:55 PM
70RT Charger
eastern,Ky
Fixed the picture!
[Re: birdtracker]
#3064138
07/31/22 06:04 PM
07/31/22 06:04 PM
70RT Charger
eastern,Ky
Don’t understand what you are saying? This is the index plate that is attached to the bellhousing if that’s what you are referring to.
[Re: 70RT Charger]
#3064140
07/31/22 06:24 PM
07/31/22 06:24 PM
Posts: 8,871 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
When you install the .014 offset dowels you can tweak them slightly to solve the other offset issue.
Furthermore, having the dial indicator offset such as it is is not doing you any favors as far as accuracy goes.
[Re: Stanton]
#3064149
07/31/22 06:56 PM
07/31/22 06:56 PM
70RT Charger
eastern,Ky
Furthermore, having the dial indicator offset such as it is is not doing you any favors as far as accuracy goes. I understand what you are saying but I have the indicator mounted dead center on the crank. I’ll order a different indicator that won’t allow to me to have any offset and go back over what I did.
[Re: 70RT Charger]
#3064193
07/31/22 10:53 PM
07/31/22 10:53 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
You can’t use the numbers you have to select dowels. With the poor positioning of the indicator, your numbers aren’t accurate. Get the indicator radially centered and on the same angle as the bell surface. Only after doing that will you have good numbers to work with. After getting good numbers, you can rotate the dowels to zero in on your target.
[Re: 70RT Charger]
#3064198
07/31/22 11:30 PM
07/31/22 11:30 PM
Posts: 31,027 Oregon
AndyF
Here is the set up that I use. I had to build it myself since I couldn't find anyone who sold a tool that worked with my parts.
[Re: AndyF]
#3064212
08/01/22 12:41 AM
08/01/22 12:41 AM
Posts: 4,457 Washington
madscientist
Washington
Here is the set up that I use. I had to build it myself since I couldn't find anyone who sold a tool that worked with my parts. Do you make that tool??
[Re: 70RT Charger]
#3064216
08/01/22 01:20 AM
08/01/22 01:20 AM
Posts: 43,161 Bend,OR USA
Cab_Burge
What does the 14 offset mean written at the top of the adapter?
