edelbrock nhra head #3063519
07/29/22 10:11 AM
07/29/22 10:11 AM
westerly, ri. usa
440lebaron Offline OP
westerly, ri. usa
picked up a set of edelbrock 60917 nhra s/ss heads anybody done anything with them, mill, check cc's etc
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: edelbrock nhra head [Re: 440lebaron] #3063520
07/29/22 10:20 AM
07/29/22 10:20 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I’ve never had any in my hands, but my understanding is it’s quite a bit of work to make them “legal”.
Ports are too big, guides are the wrong diameter, etc.
Re: edelbrock nhra head [Re: fast68plymouth] #3063529
07/29/22 10:41 AM
07/29/22 10:41 AM
westerly, ri. usa
westerly, ri. usa
part number is approved by nhra with a hp/weight factor penalty
Re: edelbrock nhra head [Re: 440lebaron] #3063530
07/29/22 10:43 AM
07/29/22 10:43 AM
So. Burlington, Vt.
So. Burlington, Vt.
It still has to comply with all the same measurements as the OE heads.
Chamber volume, runner volumes, valve stem diameters, valve head diameters.
Re: edelbrock nhra head [Re: fast68plymouth] #3063540
07/29/22 10:56 AM
07/29/22 10:56 AM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Some folks are using OE parts rather than carry the weight penalty. That late model combo should not be a problem finding usable iron heads.
Go to the races and make friends, ask questions. Plenty of BB Mopar class guys in D1.
Re: edelbrock nhra head [Re: CMcAllister] #3063544
07/29/22 11:04 AM
07/29/22 11:04 AM
So. Burlington, Vt.
So. Burlington, Vt.
Here ya go:
Re: edelbrock nhra head [Re: fast68plymouth] #3063554
07/29/22 11:14 AM
07/29/22 11:14 AM
westerly, ri. usa
westerly, ri. usa
yep, familiar with nhraracer.com,right now running in super/street to shake down chassis, with 383, no fuel check or scales, got them cheap, not sure what I'll use, have a couple of sets of 452's, pistons came in today, most likely next season, maybe t/tune November, shop said it would be nice to have a new head with the valves nice and high
Re: edelbrock nhra head [Re: 440lebaron] #3063561
07/29/22 11:23 AM
07/29/22 11:23 AM
So. Burlington, Vt.
So. Burlington, Vt.
I’d suggest getting the runner volumes checked before going too far.
They’re likely already larger than the limit.
My understanding is the valve guides are 11/32” instead of the required 3/8”.
That’s easy enough to measure.
Re: edelbrock nhra head [Re: fast68plymouth] #3063571
07/29/22 11:43 AM
07/29/22 11:43 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
From what I saw they’re made like the 64-66 head (closed chamber small ex valve) and after they’re made the same as the later head you still lose compression because they’re aluminum. The advantage is you’re able to move stuff around a little for better flow. But $$$ better left for the big dogs imo.
Re: edelbrock nhra head [Re: CMcAllister] #3063572
07/29/22 11:45 AM
07/29/22 11:45 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
The last write-ups or videos I've seen on a couple of BBM Stockers showed OEM iron heads. Anybody know of any using the Edelbrock NHRA head?
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: edelbrock nhra head [Re: Brad_Haak] #3063577
07/29/22 11:52 AM
07/29/22 11:52 AM
So. Burlington, Vt.
So. Burlington, Vt.
I don’t know if he’s currently using them, but I’m pretty sure Larry Hill runs/ran them in his 440-6 70 Cuda.
I also think Doug Duell used them in his 69 cuda(no hp penalty with them on that combo).
Re: edelbrock nhra head [Re: Brad_Haak] #3063578
07/29/22 11:52 AM
07/29/22 11:52 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Jim Hale did on his 66 383 Belvedere wagon, record holder
Re: edelbrock nhra head [Re: cudaman1969] #3063593
07/29/22 12:26 PM
07/29/22 12:26 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
OK, so they are being used by some people. Thx
Re: edelbrock nhra head [Re: Brad_Haak] #3063653
07/29/22 03:09 PM
07/29/22 03:09 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I'd talk to Don Little or Steve Wann in Modesto, CA. That would be a good place to start for info.
Floyd Lippencott IV
Re: edelbrock nhra head [Re: mr_340] #3063659
07/29/22 03:36 PM
07/29/22 03:36 PM
So. Burlington, Vt.
So. Burlington, Vt.
It would def be interesting to hear their thoughts on the NHRA Mopar Ede heads........to be used in stock.
Re: edelbrock nhra head [Re: fast68plymouth] #3063662
07/29/22 03:49 PM
07/29/22 03:49 PM
westerly, ri. usa
westerly, ri. usa
going to be interesting to see what valve sizes are in them, instructions say 2.14/1.81 states 60917 is nhra legal version of 60919
Re: edelbrock nhra head [Re: 440lebaron] #3063676
07/29/22 04:13 PM
07/29/22 04:13 PM
So. Burlington, Vt.
So. Burlington, Vt.
I’d be interested in seeing pics of what you have.
My old catalog shows them sold as bare heads only.
In the instruction sheet:
Quote
60917 is a NHRA Legal (Stock/Super Stock) version of 60919. All of these cylinder heads feature 210cc intake ports and 70cc exhaust ports.
As I mentioned previously....... get out the burette.
The max legal runner volume for them is 203/64.
Re: edelbrock nhra head [Re: fast68plymouth] #3063692
07/29/22 05:08 PM
07/29/22 05:08 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Found this earlier on ClassRacer: https://classracer.com/classforum/showthread.php?t=82319
Looks like if the OP decides he doesn't want them after all, he should contact Larry Hill since LH posted he's looking for a set at the end of that thread.
Re: edelbrock nhra head [Re: Brad_Haak] #3063696
07/29/22 05:38 PM
07/29/22 05:38 PM
NY
B1duster Offline
B1duster  Offline
NY
Here you go.
https://www.jegs.com/i/Edelbrock/350/60917/10002/-1
Looks like a bare 60929 with nice NHRA logo added on
Re: edelbrock nhra head [Re: B1duster] #3063697
07/29/22 05:46 PM
07/29/22 05:46 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
Originally Posted by B1duster
Yeah, about that...
" Free Shipping - Estimated to ship direct from manufacturer on 07/28/24 , pending manufacturer availability."
Does Edelbrock have any?
