Page 4 of 5 1 2 3 4 5
Re: Header thread [Re: moparx] #3063372
07/28/22 04:55 PM
07/28/22 04:55 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Originally Posted by moparx
mentioning bullhorns, what advantage do they serve ?
i am asking this because i seem to be seeing more of them on fast cars.
TIA for helping me to understand.
beer
ON a car with no wheelie bars, they are supposed to add (from the exhaust velocity aimed up) almost 30lbs to the front, without carrying 30lbs if that makes sense.
Helps keep the front down
....BAD A$$ STREET CAR.....
Re: Header thread [Re: JERICOGTX] #3063373
07/28/22 04:55 PM
07/28/22 04:55 PM
I'm assuming Bullhorns mean the collector pointing up outside the body, correct or not?
I would be temted,if i had set, to try pointing them back towards the rear bumper for additional ET work devil
Greedy I BE whistling grin
Re: Header thread [Re: n20mstr] #3063604
07/29/22 12:45 PM
07/29/22 12:45 PM
moparx Offline
moparx  Offline
beer
JericoGTX : Downforce. While not a lot, on a fast car, you take every bit of advantage you can to not get air under the car.
n20mstr : ON a car with no wheelie bars, they are supposed to add (from the exhaust velocity aimed up) almost 30lbs to the front, without carrying 30lbs if that makes sense.
thanks for helping me understand this guys ! up bow
beer
Re: Header thread [Re: Al_Alguire] #3063644
07/29/22 02:44 PM
07/29/22 02:44 PM
N
n20mstr Offline
n20mstr  Offline
N
Originally Posted by Al_Alguire
Nice tape biggrin
Looking good.
You know us body guys , we use masking tape for everything.
Tape removed
Re: Header thread [Re: n20mstr] #3063843
07/30/22 11:34 AM
07/30/22 11:34 AM
N
n20mstr Offline
n20mstr  Offline
N
weld
Re: Header thread [Re: Cab_Burge] #3063885
07/30/22 02:34 PM
07/30/22 02:34 PM
CA
crackedback Offline
crackedback  Offline
CA
Drag from the tube hanging outside the body would likely outstrip any "thrust" from the headers
Re: Header thread [Re: crackedback] #3064100
07/31/22 03:15 PM
07/31/22 03:15 PM
moparx Offline
moparx  Offline
that's one thing [among others] that makes me not quite understand why bullhorns are used.
beer
Re: Header thread [Re: moparx] #3064111
07/31/22 04:24 PM
07/31/22 04:24 PM
When it comes to aerodynamics testing Mopar did a bunch of that using crepe paper strips on one of their test Dusters back in the mid 1970s filming it and then looking at each frame from the starting line to the finish line in the 1/4 mile.
I've seen the same testing done on small racing airplanes the nose, fuselage, wings, rudder and tail designs all come into play on aerodynamic drag,
I owned and flew a Piper 260 Comanche single engine 5 place airplane, it would average around 180 MPH indicated air speed straight and level on 60% full power above 9500 Ft. above sea level, the fuel consumption got a lot better the higher you flew do to needing to lean it out for the thinner air up
We were flying back to SO CA from visiting our grandkids in Seatle WA, we were above a cloud layer at 11,500 ft the outside air temps were right at 5 F, the ride was very smooth, and I was bored so I started playing around with prop pitch RPM, sliding my seat all the way back as far as it would go made the airplane speed up around 4 MPH boogie
Slowing the prop speed down from 2400 RPM to 2300 RPM picked up 12 MPH shock
I ended up trying from 2000 RPM to 2600 RPM in 500 RPM increments, that airplane that day a in those weather at that altitude like 2300 RPM best.
My message is to test before deciding on what will work versus what you may think will or won't work on our toys twocents wrench scope work up
Lots of ways to slow down, not so many on making our cars and other toys faster, test, test and test some more wrench up
Re: Header thread [Re: HardcoreB] #3064505
08/01/22 09:35 PM
08/01/22 09:35 PM
Nebraska
TT5 Valiant Offline
TT5 Valiant  Offline
Nebraska
2.250 tube with 4” collector B1 RB in a Foxbody.
Re: Header thread [Re: moparx] #3064549
08/02/22 05:19 AM
08/02/22 05:19 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
beer
Plenty of folk still using them, people have done testing with positive results as well.
https://www.yellowbullet.com/thread...ust-a-fad-or-does-it-really-work.230383/
https://www.dragzine.com/news/upturned-bull-horn-exhaust-just-a-fad-or-does-it-really-work/
Some older articles for your reading
Alan Jones
Re: Header thread [Re: LA360] #3064563
08/02/22 07:36 AM
08/02/22 07:36 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
beer
Wow! educational, thanks ! up
Re: Header thread [Re: Tig] #3064575
08/02/22 08:54 AM
08/02/22 08:54 AM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Mine....old way.....new way...Notice the size difference in the tubes...
Re: Header thread [Re: LA360] #3064667
08/02/22 02:29 PM
08/02/22 02:29 PM
moparx Offline
moparx  Offline
thanks for the links LA ! up
i can finally start to understand this concept.
there is quite a bit of difference between an 11 second car and a 5 [or 4] second one. biggrin
beer
Re: Header thread [Re: LA360] #3067586
08/13/22 11:21 AM
08/13/22 11:21 AM
N
n20mstr Offline
n20mstr  Offline
N
Finished product
Re: Header thread [Re: LA360] #3067643
08/13/22 02:13 PM
08/13/22 02:13 PM
CA
crackedback Offline
crackedback  Offline
CA
beer
Turning them up to help with downforce, sure. It's free weight not subject to a those post race weighing thingies, scales.
Turning them back to the rear to increase speed through additional thrust, I doubt it seriously has a positive effect. Drag vs thrust.
Re: Header thread [Re: crackedback] #3069343
08/18/22 07:16 PM
08/18/22 07:16 PM
gregsdart Offline
gregsdart  Offline
One side done, a couple pipes to fix on the other, then wrap that side. Getting close!
Re: Header thread [Re: gregsdart] #3069441
08/19/22 09:01 AM
08/19/22 09:01 AM
CJD AUTOMOTIVE Offline
Here is a set I built for my street/road race 'Cuda. It's a turbo car with 345's up front, so packaging is tight.
I'm using the Victor heads, and no one makes a header flange I liked. I bought the Stainless Headers one and figured out it's just a copy of the .dxf file for the gasket. Decided to make my own (right one is the SH flange and left is mine):
I had these water jet cut, and the port slug gave me an idea. I reduced the OD about .030", put a radius on the driven edge, and drilled a hole to attach a handle. This became my forming tool for the stubs. I formed the stub on the bench, inserted, and then formed it again in the flange. Worked out pretty good:
I used the Lego's to layout about 10 different setup's. The goal was all primaries within 1/2" of each other, easy spark plug access, and be removable without pulling the engine! I finally got there, but damn...
The other side was no easier, as I have the engine offset 1-1/2" to the passenger side.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: Header thread [Re: CJD AUTOMOTIVE] #3069442
08/19/22 09:04 AM
08/19/22 09:04 AM
Couple more, hit the posting limit above.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: Header thread [Re: CJD AUTOMOTIVE] #3069448
08/19/22 09:28 AM
08/19/22 09:28 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Wow !! Impressive stuff for sure, any pics of the whole project ?
Re: Header thread [Re: gregsdart] #3069501
08/19/22 11:15 AM
08/19/22 11:15 AM
NC
440Jim Offline
440Jim  Offline
NC
Greg,
Good to hear the progress.
What didn't you like about the #1 and #7 tubes?
