edelbrock nhra head
#3063519
07/29/22 10:11 AM
07/29/22 10:11 AM
Posts: 1,609 westerly, ri. usa
440lebaron
westerly, ri. usa
picked up a set of edelbrock 60917 nhra s/ss heads anybody done anything with them, mill, check cc's etc
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
Re: edelbrock nhra head
[Re: 440lebaron]
#3063520
07/29/22 10:20 AM
07/29/22 10:20 AM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I’ve never had any in my hands, but my understanding is it’s quite a bit of work to make them “legal”.
Ports are too big, guides are the wrong diameter, etc.
[Re: fast68plymouth]
#3063529
07/29/22 10:41 AM
07/29/22 10:41 AM
440lebaron
westerly, ri. usa
part number is approved by nhra with a hp/weight factor penalty
[Re: 440lebaron]
#3063530
07/29/22 10:43 AM
07/29/22 10:43 AM
fast68plymouth
So. Burlington, Vt.
It still has to comply with all the same measurements as the OE heads.
Chamber volume, runner volumes, valve stem diameters, valve head diameters.
#3063540
07/29/22 10:56 AM
07/29/22 10:56 AM
Posts: 11,635 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Some folks are using OE parts rather than carry the weight penalty. That late model combo should not be a problem finding usable iron heads.
Go to the races and make friends, ask questions. Plenty of BB Mopar class guys in D1.
#3063554
07/29/22 11:14 AM
07/29/22 11:14 AM
440lebaron
westerly, ri. usa
yep, familiar with nhraracer.com,right now running in super/street to shake down chassis, with 383, no fuel check or scales, got them cheap, not sure what I'll use, have a couple of sets of 452's, pistons came in today, most likely next season, maybe t/tune November, shop said it would be nice to have a new head with the valves nice and high
[Re: 440lebaron]
#3063561
07/29/22 11:23 AM
07/29/22 11:23 AM
fast68plymouth
So. Burlington, Vt.
I’d suggest getting the runner volumes checked before going too far. They’re likely already larger than the limit.
My understanding is the valve guides are 11/32” instead of the required 3/8”. That’s easy enough to measure.
[Re: CMcAllister]
#3063572
07/29/22 11:45 AM
07/29/22 11:45 AM
Posts: 1,146 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Some folks are using OE parts rather than carry the weight penalty. That late model combo should not be a problem finding usable iron heads. The last write-ups or videos I've seen on a couple of BBM Stockers showed OEM iron heads. Anybody know of any using the Edelbrock NHRA head?
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3063577
07/29/22 11:52 AM
07/29/22 11:52 AM
fast68plymouth
So. Burlington, Vt.
I don’t know if he’s currently using them, but I’m pretty sure Larry Hill runs/ran them in his 440-6 70 Cuda.
I also think Doug Duell used them in his 69 cuda(no hp penalty with them on that combo).
[Re: Brad_Haak]
#3063578
07/29/22 11:52 AM
07/29/22 11:52 AM
Posts: 8,307 fredericksburg,va
cudaman1969
fredericksburg,va
Some folks are using OE parts rather than carry the weight penalty. That late model combo should not be a problem finding usable iron heads. The last write-ups or videos I've seen on a couple of BBM Stockers showed OEM iron heads. Anybody know of any using the Edelbrock NHRA head? Jim Hale did on his 66 383 Belvedere wagon, record holder
[Re: cudaman1969]
#3063593
07/29/22 12:26 PM
07/29/22 12:26 PM
Brad_Haak
Loudoun County, VA
OK, so they are being used by some people. Thx
[Re: Brad_Haak]
#3063653
07/29/22 03:09 PM
07/29/22 03:09 PM
Posts: 3,505 DFW
mr_340
DFW
I'd talk to Don Little or Steve Wann in Modesto, CA. That would be a good place to start for info.
Floyd Lippencott IV
[Re: mr_340]
#3063659
07/29/22 03:36 PM
07/29/22 03:36 PM
fast68plymouth
So. Burlington, Vt.
It would def be interesting to hear their thoughts on the NHRA Mopar Ede heads........to be used in stock.
#3063662
07/29/22 03:49 PM
07/29/22 03:49 PM
440lebaron
westerly, ri. usa
going to be interesting to see what valve sizes are in them, instructions say 2.14/1.81 states 60917 is nhra legal version of 60919
[Re: 440lebaron]
#3063676
07/29/22 04:13 PM
07/29/22 04:13 PM
fast68plymouth
So. Burlington, Vt.
I’d be interested in seeing pics of what you have. My old catalog shows them sold as bare heads only. In the instruction sheet: 60917 is a NHRA Legal (Stock/Super Stock) version of 60919. All of these cylinder heads feature 210cc intake ports and 70cc exhaust ports. As I mentioned previously....... get out the burette. The max legal runner volume for them is 203/64.
#3063692
07/29/22 05:08 PM
07/29/22 05:08 PM
Brad_Haak
Loudoun County, VA
Found this earlier on ClassRacer: https://classracer.com/classforum/showthread.php?t=82319Looks like if the OP decides he doesn't want them after all, he should contact Larry Hill since LH posted he's looking for a set at the end of that thread.
[Re: B1duster]
#3063697
07/29/22 05:46 PM
07/29/22 05:46 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Yeah, about that... " Free Shipping - Estimated to ship direct from manufacturer on 07/28/24 , pending manufacturer availability." Does Edelbrock have any?
