Re: Caltracs A or B body front segment
[Re: John Burdine]
#3063154
07/27/22 11:40 PM
07/27/22 11:40 PM
Posts: 4,723 Moved to N.E. Tennessee
GomangoCuda
I would opt for the longer 22" springs. Agree. Some of the really fast caltrac mopars have been modified to use Chevy length springs. I suppose the instant center moves forward along with the spring eye.
[Re: GomangoCuda]
#3063205
07/28/22 08:25 AM
07/28/22 08:25 AM
Posts: 4,680 Wichita
GY3
Wichita
We run the 20" front segment in our '63 B-body.
They work fine.
Unless it's an all out effort and you're going for every last 1/10 of a second, I'd leave the longer hangers in there and just do the 20" segment leaf.
[Re: GY3]
#3063207
07/28/22 08:38 AM
07/28/22 08:38 AM
Posts: 8,873 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I think the front CalTrac segment provides very little flex, that's left to the rear segment. The front segment acts like the top bar in a 4-link or ladder bar ... very rigid. I'd leave the longer hangers in there CalTracs come with new hangers. Unless you were specific, the shorter front segments would come with standard front hangers and as a result the rear end would have to move forward to line up with the locator pin. Life would be simpler if you ordered the kit specific for the car.
[Re: StageIII]
#3063208
07/28/22 08:45 AM
07/28/22 08:45 AM
Posts: 2,923 A shed in England
Tig
A shed in England
If I was starting from scratch I'd go to 22" front segment but we have our's working OK with a 20"
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#3063295
07/28/22 01:32 PM
07/28/22 01:32 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
On a B car I used a SS spring hanger to move the axle back in the wheel well and retained the 22" from segment by relocating the rear leaf spring attachment point (in this case roller sliders).
[Re: moparx]
#3063316
07/28/22 02:23 PM
07/28/22 02:23 PM
Posts: 10,027 MN
JERICOGTX
MN
On a CalTrac setup, the longer the front segment of leaf spring, the better. IMO.
69 GTX
68 Road Runner
[Re: moparx]
#3063317
07/28/22 02:24 PM
07/28/22 02:24 PM
Posts: 10,027 MN
JERICOGTX
MN
I would opt for the longer 22" springs. Agree. Some of the really fast caltrac mopars have been modified to use Chevy length springs. I suppose the instant center moves forward along with the spring eye. aren't chevy length springs 50/50 length segments ? Yes. So are Fords. Just like CalTracs were originally designed for.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3063349
07/28/22 03:48 PM
07/28/22 03:48 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
My car is an A body with the 20" segment. I have wondered about making the change to the 22". Low 1.4 60s but it crushes the tire even with my shocks 1 click away from full stiff. It unloads the tire a little bit at 8' out. I am relocating my lower shock mounts to stand the shock up a little more in hopes of gaining some more control without buying new shocks or springs.
68 Barracuda Formula S 340
[Re: JERICOGTX]
#3063352
07/28/22 04:07 PM
07/28/22 04:07 PM
Posts: 2,077 CA
crackedback
CA
On a CalTrac setup, the longer the front segment of leaf spring, the better. IMO. ^^^^ THIS!!!
[Re: StageIII]
#3063375
07/28/22 05:05 PM
07/28/22 05:05 PM
Posts: 43,198 Bend,OR USA
Cab_Burge
Do you want to move the rearend rearward by two inches by using the longer B body style leaf springs? If not don't use them The tech at Cal Tracks should know better to tell you that two inches longer it doesn't matter, shame on him (maybe he should ask his girlfriend about two inches longer mattering or not : grin:)
[Re: Tig]
#3063396
07/28/22 06:28 PM
07/28/22 06:28 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I never noticed the wind turbine sticking out of the hood before.
Hybrid with supplemental wind power??
[Re: fast68plymouth]
#3063401
07/28/22 06:56 PM
07/28/22 06:56 PM
Tig
A shed in England
Hybrid with supplemental wind power?? Anything for an extra 10th
[Re: Cab_Burge]
#3063407
07/28/22 07:18 PM
07/28/22 07:18 PM
GomangoCuda
Do you want to move the rearend rearward by two inches by using the longer B body style leaf springs? If not don't use them The tech at Cal Tracks should know better to tell you that two inches longer it doesn't matter, shame on him (maybe he should ask his girlfriend about two inches longer mattering or not : grin:) Uh, he has a b body so all he has to do to use b body springs is put the stock hangers back on. No change in rear end location.
