Caltracs A or B body front segment #3063120
07/27/22 08:54 PM
07/27/22 08:54 PM
Wisconsin
StageIII Offline OP
StageIII  Offline OP
Wisconsin
I got a 1967 coronet with 002 & 003 springs on it. Thinking about switching over to Caltracs. Should I run A body Caltracs springs which have a 20” front segment or the B body 22” front segment? Talked to Calvert today and they said it really didn’t matter???
Re: Caltracs A or B body front segment [Re: StageIII] #3063123
07/27/22 09:07 PM
07/27/22 09:07 PM
Chesterfield Twp. Mi.
John Burdine Offline
I would opt for the longer 22" springs.
Re: Caltracs A or B body front segment [Re: John Burdine] #3063140
07/27/22 09:53 PM
07/27/22 09:53 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
002/003 have the 20" ft segment, so on that car the front hangers are longer to work with them.
Shorter ft segment is less susceptible to "wrap" than a longer segment IF all else is equal.
On a Cal-Trac setup, I don't know if segment length matters, as the way I understand it, the bar is doing more of the work.
Everyone with Cal-Tracs seems to like them better than the SS springs.
Re: Caltracs A or B body front segment [Re: John Burdine] #3063154
07/27/22 11:40 PM
07/27/22 11:40 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Agree. Some of the really fast caltrac mopars have been modified to use Chevy length springs. I suppose the instant center moves forward along with the spring eye.
Re: Caltracs A or B body front segment [Re: GomangoCuda] #3063205
07/28/22 08:25 AM
07/28/22 08:25 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
We run the 20" front segment in our '63 B-body.
They work fine.
Unless it's an all out effort and you're going for every last 1/10 of a second, I'd leave the longer hangers in there and just do the 20" segment leaf.
'63 Dodge 330
11.19 @ 121 mph
Re: Caltracs A or B body front segment [Re: GY3] #3063207
07/28/22 08:38 AM
07/28/22 08:38 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I think the front CalTrac segment provides very little flex, that's left to the rear segment. The front segment acts like the top bar in a 4-link or ladder bar ... very rigid.
Quote
CalTracs come with new hangers. Unless you were specific, the shorter front segments would come with standard front hangers and as a result the rear end would have to move forward to line up with the locator pin. Life would be simpler if you ordered the kit specific for the car.
Re: Caltracs A or B body front segment [Re: StageIII] #3063208
07/28/22 08:45 AM
07/28/22 08:45 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
If I was starting from scratch I'd go to 22" front segment but we have our's working OK with a 20"
Re: Caltracs A or B body front segment [Re: Tig] #3063295
07/28/22 01:32 PM
07/28/22 01:32 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
On a B car I used a SS spring hanger to move the axle back in the wheel well and retained the 22" from segment by relocating the rear leaf spring attachment point (in this case roller sliders).
Re: Caltracs A or B body front segment [Re: GomangoCuda] #3063312
07/28/22 02:19 PM
07/28/22 02:19 PM
moparx Offline
moparx  Offline
aren't chevy length springs 50/50 length segments ? shruggy
beer
Re: Caltracs A or B body front segment [Re: moparx] #3063316
07/28/22 02:23 PM
07/28/22 02:23 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
On a CalTrac setup, the longer the front segment of leaf spring, the better. IMO.
69 GTX 68 Road Runner
Re: Caltracs A or B body front segment [Re: moparx] #3063317
07/28/22 02:24 PM
07/28/22 02:24 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
beer
Yes. So are Fords. Just like CalTracs were originally designed for.
Re: Caltracs A or B body front segment [Re: JERICOGTX] #3063349
07/28/22 03:48 PM
07/28/22 03:48 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
My car is an A body with the 20" segment. I have wondered about making the change to the 22". Low 1.4 60s but it crushes the tire even with my shocks 1 click away from full stiff. It unloads the tire a little bit at 8' out. I am relocating my lower shock mounts to stand the shock up a little more in hopes of gaining some more control without buying new shocks or springs.
68 Barracuda Formula S 340
Re: Caltracs A or B body front segment [Re: JERICOGTX] #3063352
07/28/22 04:07 PM
07/28/22 04:07 PM
CA
crackedback Offline
crackedback  Offline
CA
^^^^ THIS!!!
Re: Caltracs A or B body front segment [Re: StageIII] #3063375
07/28/22 05:05 PM
07/28/22 05:05 PM
Do you want to move the rearend rearward by two inches by using the longer B body style leaf springs?
If not don't use them tsk work
The tech at Cal Tracks should know better to tell you that two inches longer it doesn't matter, shame on him down(maybe he should ask his girlfriend about two inches longer mattering or not whistling devil: grin:)
Re: Caltracs A or B body front segment [Re: Cab_Burge] #3063394
07/28/22 06:14 PM
07/28/22 06:14 PM
Melbourne , Australia
LA360 Online boogie
LA360  Online Boogie
The GM guys run the 24" orthe S-10 25" front segment. If it will fit, run the longer 22" front segment
Alan Jones
Re: Caltracs A or B body front segment [Re: Tig] #3063396
07/28/22 06:28 PM
07/28/22 06:28 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I never noticed the wind turbine sticking out of the hood before.
Hybrid with supplemental wind power??
Re: Caltracs A or B body front segment [Re: fast68plymouth] #3063401
07/28/22 06:56 PM
07/28/22 06:56 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
grin Anything for an extra 10th grin
Re: Caltracs A or B body front segment [Re: Cab_Burge] #3063407
07/28/22 07:18 PM
07/28/22 07:18 PM
GomangoCuda Offline
GomangoCuda  Offline
Uh, he has a b body so all he has to do to use b body springs is put the stock hangers back on. No change in rear end location.
Re: Caltracs A or B body front segment [Re: JERICOGTX] #3063443
07/28/22 09:09 PM
07/28/22 09:09 PM
AZLIVN
SLO-KID Offline
SLO-KID  Offline
AZLIVN
Iirc Toothjerker still runs a 20” front
Re: Caltracs A or B body front segment [Re: SLO-KID] #3063457
07/28/22 09:55 PM
07/28/22 09:55 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Getting the shock right will have way more impact than the 20" or 22" length.
They make a 21" too, that's what's on my 62 Savoy.
